Spring Spacers?
So i just got new murano wheels on my SVX but the rears slightly rub on the outside fender when i hit a bump or corner hard. I still have the stock struts and springs so they're not adjustable at all, and i dont have the money to buy anything major. But I was lookin around the internet and found these:
http://www.autoanything.com/suspensi...A2933A0A0.aspx http://www.jcwhitney.com/autoparts/I...=group_listing http://www.jegs.com/i/Mr.+Gasket/720/1285/10002/-1 Has anyone had any experience with any of these? Or any other suggestions that i could do to raise my car about an inch? Thanks, Jeremy
-Jeremy- 1994 Barcelona Red LS 97,xxx miles Mods: - JVC Indash head unit, polk 6.5's, 6X9's, 2" tweeters, and 8" JL audio subwoofer run off of MA Audio M589I amp. Fiberglass Front splitters molded in, Shifted back stock spoiler, & repainted minor faded parts (Mirrors, rear quarter garnishes),18" murano 5-spoke wheels w/cooper zeon 2xs tires, '97 grille |
Re: Spring Spacers?
Should work, but I wouldn't count on those as a permanent solution. The ideal thing would be to go to a stiffer spring with the same ride height and limit suspension travel over bumps.
If I ever do get around to fitting STi suspension into my car, I may look into also fitting Forester suspension for winter, to lift it up and give me some extra ground clearance
Re: Spring Spacers?
Re: Spring Spacers?
No, sorry. I'm sure there's someone who can tell you, or at least someone who has a spring out of the car that they can measure.
Re: Spring Spacers?
They'll raise it but will also take a link out of action for the suspension which will make your springs weaker and then you'll be more likely to rub over bumps. You're better off making a spacer which goes atop or at the bottom of the spring between the collar or top mount and the spring.
Re: Spring Spacers?
Thread Tools | |
Display Modes | |
