My idling problem is SOLVED!!!!
Since I bought the car, 2 months ago, Ive been having nothing but problems with it. The rear lsd is out, it wouldnt run in the morning, and it idles and dies at every stoplight. Well, I now fixed the idling and dying problem. I went to the Subaru dealer and had them check it out. Too bad they had no idea what they were talking about, because they told me that I had to change the MAF sensor and both O2 sensors. Well, I did, and NOTHING was different. During this entire time, I kept hearing a whistling sound coming from the engine bay, so I figured that it was a vacuum problem. I then checked every inch of the Vacuum hose and ALL the lines, without finding a hole or anything! I then almost quit and almost sold the car. At the end, it turns out that I forgot one vacuum line that was not in reach, it was under the intake manifold. I decided just to go ahead and take off the entire manifold to get to that line to check it out, but before that, i started to unbolt the screws for the intake manifold only to find out that they were loose as hell!!! I could of unscrewed them with my fingers!! Turns out, there was tons of air escaping because they were tightened worth a damn. And thats what was making the whistling sound. So then I tighten the bolts and go out for a drive......no whistling....no dying....no out of control RPM...the car was PERFECT! It was also MUCH faster! I love this car!!! Now all i have to do is figure out why my rear wheels arent spinning, and Ill be good!
wish my problem was that easy
did u figure out what that vacuum hose under manifold is for? mine is damn old and i need to change but still need to take manifold out. i got bad idle and bad perfomance now. when its cold for first 2 mins its good as but after it just drops RPMs and shakes :s with 98 petrol its better but still not good |
If it was the hose in the Center of the Manifold, it's your PCV valve hose.
NO....I DIDNT COMPLETELY TAKE IT OFF...SO I COULDNT CHECK...SORRY I CANT HELP
anyways gonna change em all just to be sure
they dont cose too much pcv is cheap as itself anyways |
Which one was loose? I discovered the same thing with mine! I could literally unscrew the front right bolt. Anyone have the torque specs for the manifold?
All 4 on the right side of the manifold were loose...thats why it was making suck a loud whistle and had such a great loss of air
actually i think if u have unscrewed bolts, then it would suck the air not from the intake but from the leak..
so u were not loosing anything just ur MAF was giving wrong values (less air goes from air filter) plus was having HOT air just from center of engine that what was wrong cheers Sergi |
PCV
Why can I not locate the PCV valve on this thing? I have followed every vacuum line I can and do not see anything resembling the PCV. Can anyone advise? Thanks
wrong place to ask it but
look it how to folder there is description about taking off the pcv to see the pcv u have to take off both plastic shields from top of manifold, 2 mins job but to take the bugger out.... wont be that easy |
Re: PCV
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
Re: Re: PCV
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
If it's the first time it's been changed you may need "The SVX PCV Tool"
