Old 05-14-2009, 07:11 PM
Gamesy's Avatar
Gamesy Gamesy is offline
torque converter issue
managed to seat the TC into the bellhousing and aligned onto the splines but cant get the tc to turn so i can bolt it to the flexplate,
Any ideas what might be wrong? and its not in park, tried all gears
Old 05-14-2009, 07:17 PM
Re: torque converter issue
It is not fully seated and slammed up against the flexplate. Pull the trans back out and rebuild the pump you have destroyed
Old 05-14-2009, 07:52 PM
Gamesy's Avatar
this wasnt when it was bolted to the flexplate yet, this was just mounting the tc into the bellhousing b4 raising the tranny
Old 05-14-2009, 08:02 PM
Well, that sa different store then. If you lift it will it spin?
Old 05-14-2009, 08:17 PM
Gamesy's Avatar
i dont see how lifting the tranny will make a diff when its just resting on blocks, Can turnthe inner shaft by hand but the out part of the shaft was dead solid, but for the the inner shaft, it can be moved in and out, not sure if thats normal or not...
Old 05-14-2009, 08:19 PM
Gamesy's Avatar
can get the tc to spin when u pull it out by a centimeter so i wonder if its seated too far? but the starter wont fit onto it at that point if that helps
Turning the inner and not the outer is normal. I meant lift the torque converter from the front side and try to spin it. I don't think it is seated properly and the teeth are rubbing the bellhousing
Old 05-14-2009, 09:01 PM
Gamesy's Avatar
just checked, the teeth arnt rubbing against the bellhousing but i did manage to get it to spin 180 degrees after that i can hear a click/knock sound coming from the tranny, any suggestions?
Old 05-14-2009, 11:52 PM
Gamesy's Avatar
since i can get it to rotate 180 would it be safe to bolt it to the engine and try cranking it over through the drive pulley? or would that break something in the tranny?
Old 05-15-2009, 08:41 AM
longassname's Avatar
Just some dude.
Nope, if it's not turning smoothly either you just don't have it splined in all the way or you did in fact smash your pump (which unfortunately others before you have done and apparantly isn't that hard for the uninitiated to do).
Old 05-15-2009, 08:50 AM
Just some dude.
If I remember correctly you're using some other type of subaru transmission (not svx transmission). Make sure you are using the correct input shaft to match your torque convter too. Not all subaru's use the same torque converter and input shaft. The input shaft installs into the transmission before you install the torque converter. When it is fully seated the o-ring is very close to the outer splined shaft.
During installation there are 3 things which much spline together. The two notches in the pump driveshaft spline with the two tabs of the pump rotor. The splines on the solid outer shaft spline into the stator of the torque converter. The splines on the input shaft spline into the turbine of the torque converter. For some reason people have difficulty getting this right. Putting the transmission in with it wrong always results in breaking the pump.
Old 05-15-2009, 11:07 AM
Gamesy's Avatar
i'm still using the stock svx 4eat, i was inquiring about the other ones incase the tc was messed but its fine, how do you check to make sure the pump isnt smashed?
When i managed to get it to rotate 180 i was turning it left and right till i heard like a poping sound then i could turn it even more but now its at the point where i cant just slide the tc off anymore so would it be splined properly?
Old 05-15-2009, 01:25 PM
Just some dude.
i'm not sure what to say except I'm not sure what you've broken but I'd be inclined to believe something is broken. I'm not sure what to recomend either. I don't think the pump shaft is long enough to remove it from the torque converter and test the pump with it.
Maybe get the converter back off and pull the input shaft and try to spline it in the turbine and turn it?
Old 05-15-2009, 03:03 PM
Gamesy's Avatar
if the pump is busted, how much would it cost to either rebuild it yourself or get it rebuilt?
Old 05-17-2009, 07:26 PM
Gamesy's Avatar
ok ever since i got the tc to have a free back and forth half rotation i cant seem to get it into position to pull the tc back off, any suggestions?
