Crank pully nut
I have the engine out for a complete reseal, water pump, and timing belt change but can't figure out how to get the crank pully off without damaging something... The nut is on there pretty tight.
I'd like to wedge something in the flexplate but that seems like it would be an unwise decision. Is it safe to use an impact wrench on that crank nut? Also, what should I torque it to once I put it back on? Thanks in advance! |
Re: Crank pully nut
Probably your best bet is to block the flex plate and use an impact wrench.
I had one real stubborn one, I had to use a big pipe wrench with a 3 foot pipe on the outer pulley, and a breaker bar with a 3 foot pipe to turn the bolt.
Re: Crank pully nut
If you run into a snag, use the starter!
Is a bit scary but works like a dream I use a big break over bar with big old socket and slide a plastic pipe over the handle and brace the whole thing against the frame by the battery. Pad the handle-plastic pipe with some padding to protect the top of fender and turn the ignition switch to start. Turn key off when nut breaks loose... right then! |
Re: Crank pully nut
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
Re: Crank pully nut
Yeah, the starter is fine, but;
Re: Crank pully nut
<<Is it safe to use an impact wrench on that crank nut?>>
its a crank bolt. yes, impact gun will work fine.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
