Old 07-20-2006, 12:04 PM
Bizarre Bizarre is offline
Send a message via AIM to Bizarre Send a message via Yahoo to Bizarre Send a message via Skype™ to Bizarre
Paint problem
Any of you have this paint problem on the "SVX" panel?
Got a solution?
'95 SVX LSI Black, just wire mod.
New speakers + homemade front mounts.
"In times of peace, a gentleman keeps his sword at his side." Sun Tzu c 300 b.c.
Old 07-20-2006, 12:12 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Ouch! You could get another one. Or take that one and get it re-done. There isn't much you can do with Clear Coat that's messed up like that.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 07-20-2006, 01:07 PM
Got it too...probably as a result of trying everything in the book to remove overspray.
Old 07-20-2006, 02:36 PM
Local dealership says they cannot remove the panel without snapping the points that hold it in. Crap.
Old 07-20-2006, 02:48 PM
That's about right. Expect to replace all the clips that hold it in place.
Old 07-20-2006, 02:59 PM
dcarrb dcarrb is offline
Mine looks kind of like that (not quite so pronounced), and so do the tops of the mirrors. I experimented on one side, masking around the panel, sanding very lightly so as to not cut too much into the color base, then spraying with rattlecan clear coat. Looks better, but I did a ham-fisted job of spraying and got a lumpy, orange-peel thing going on... too thick, I guess. Could probably still be buffed-out. Someone with more patience, the right touch and know-how could have done a much better job.
dcb
Old 07-21-2006, 04:02 PM
subster subster is offline
I don't seem to have that problem on my 95 polo green. Hey your antenna goes all the way down!
Old 07-21-2006, 05:16 PM
Yeah antenna is fine. Spray it with wd40 or slick 50 liquid spray and it should go all the way down. Do not get it on your paint.
Old 07-21-2006, 05:25 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
That was the first sign my car gave of paint "failure" . I would say you should either take it to a paint shop for a new coat of clear, or if you've got good painting skill you can just rough it up, mask it, and re-spray like dcarrb did. Also, start watching your sunroof, rear view mirrors, and spoiler if you got one. They were the next ones to go on my car.
Old 07-21-2006, 05:43 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
This problem's happened to some SVX's spoilers and roofs as well...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-22-2006, 05:23 PM
KevinM KevinM is offline
My teal is doing the same thing...
1992 Teal LS-L w/ 150k miles bought March '06 ... stock
Old 07-23-2006, 10:29 PM
dmnknightomega6 dmnknightomega6 is offline
Amen. my plastic parts were faded, i saved the window sill pieces by rubbing on tons of wax. like moisturizing it.
Yes to all the parts mentioned... my rust is starting to flake. it bubbles. my suggestion is if you are not picky,, scrape the rust off and retouch with paint. if its getting worse. repaint!
Old 07-24-2006, 04:15 PM
It's Just Eric's Avatar
Missing in action
ClearcoatsShot.AnyCompetentBodyShopCanRepaintThatF orProbly75-100Bucks.
OrMakeItEasierOnThemAndHAveThemResprayTheTrunklid, themPanels,AndTheRoof.
ThatllProblyRunAbout400Bucks,ButYouWouldntHaveToWo rryAbout
ClearcoatForAGood10Years
IfYouDecideToTackleItYourself,WetSandItWith400Grit .FeatherTheEdge
OfTheClearcoatOut(WhenYouRunYourHandAcrossItThereW ontBeAnEdge)
DONTbreakThroughTheColor,OtherwiseYourBackToTheFir stParagraph.
Anyhow,UseSome1500GritWetToSandDownAllTheUneaffect edAreasOnThatPanel.
WhileSandingYoullSeeTheOrangePeelPatternThatEmerge sFromTheFactory.Sand
JustUntillThereIsNoMorePeel.DryItOffRealRealGood,T apeItOff,AndSprayOnSomeClear.
DoAlotOfCoats.OnceItIsDry(LetItSitOVernight)WetSan dItwith1500AgainUntillTheres
NoMoreOrangePeel,ThenBuffIt.ShouldLookDamnGood
Hell,WhileYourAtIt,SandTheWholeCarWith1500ToRemove TheORangePeelFromThe
FactoryAndBuffItOut.YoudBeSuprisedHowMuchBetterItL ooks
(ThoughI'dPractiveOnTheWife'sCarFirst)
GoodLuck
R.I.P Cool Signature.
