Old 01-22-2014, 06:23 PM
carlhoffmann carlhoffmann is offline
4 eat autos
I have 8 svx cars in storage which get very little use. on 4 of them i get clunking and shudder, i put 2 tubes of dr trannys in each...problem solved...but for how long i dont know as i only go around the block once a month , no further as they are not legal on the road [unregistered] has anyone else used this product and had any success.
Old 01-23-2014, 08:20 AM
longassname's Avatar
Just some dude.
Significant Technical Input
Re: 4 eat autos
I'm not familiar with that product. I use http://lubegard.com/~/C-113/LUBEGARD...ATF+Protectant which prevents the transfer clutch binding you are describing, extends fluid life, and makes the transmission run cooler and shift nicely.
Most ad ins are friction modifiers. Lots of them work to prevent the transfer clutch binding. You can even use lsd additives. The lubegard atf protectant and platinum atf protectant are the gold standard for atf additives though.
Old 01-23-2014, 09:33 AM
Re: 4 eat autos
dr trannys is a lubegard product made in the USA .
Old 01-23-2014, 10:33 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Smile Re: 4 eat autos
Carl,
you should arrange another BBQ at yours - then we could take them all out at once !!!
Old 01-23-2014, 11:30 AM
Just some dude.
Re: 4 eat autos
So it is..
Is it a lot less expensive?
Old 01-23-2014, 02:28 PM
Re: 4 eat autos
thanks longassname, for over 50 years i was a car dealer and for the last 10 years a subaru dealer, i retired 24 years ago , ive always been wary of additives bardahl motor up..stp and all the other gunk shoved in engines, the only ones i would ever use are chemiweld [for cracked heads and pourus blocks. but i was surprised how lubegard [dr trannys] worked. for how long i dont know..im a subaru addict from my first drive in a 1300cc gsports 1972.forget the 1400cc disaster after that, i also love the earlier vortex [alycone in the states].my first was a 360cc sub..
Old 01-24-2014, 02:27 AM
Re: 4 eat autos
lubegards dr tranny is on ebay about $6 us a tube, postage to nz more than doubles the price. there are many retailers selling it on ebay.
Old 01-24-2014, 07:20 PM
Just some dude.
Re: 4 eat autos
I suppose the shipping would be even worse for the atf protectant since they are many times the ounces--unless you found a retailer that will use usps flate rate shipping.
Old 02-10-2014, 12:58 AM
ShaneHobson ShaneHobson is offline
Re: 4 eat autos
I park in an underground car park and have to make four tight 3 point turns every day to get in and out of my car park. On every turn my car would shudder and it fought against the transmission to make the tight turns.
On Carl's recommendation I bought two tubes of Dr Tranny's
Thanks for the 2 tubes of Dr Tranny (I still owe you for the second pair of tubes). I poured it into my transmission down the filler pipe.
As promised, the binding problem has gone completely.
Thank you Carl, another troubling problem solved.
Old 02-10-2014, 07:45 AM
THE NEW GUY THE NEW GUY is offline
Re: 4 eat autos
I have the contrary problem: no rear transmission until I press the gas more than 1/3. And then a sudden shock. In the snow, this is critical because the front wheels are spinning, the speedometer shows up to 40kph, but the car is not moving until I press the gas a little more. the sudden shock indicates that the rear wheels are engaged and then the car moves. I changed the transmission last year and I open the tail cover (where the solenoid C is located). I used silicone to close it again (no gasked).
Old 02-10-2014, 12:11 PM
NiftySVX NiftySVX is offline
Send a message via AIM to NiftySVX
Re: 4 eat autos
Your Duty C is bad.
2007 GS 450h-Active Stabilizer/Radar cruise
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Toyota Master Diagnostic Technician (former life)
Old 02-11-2014, 06:32 PM
Re: 4 eat autos
Originally Posted by NiftySVX View Post
Your Duty C is bad.
ok. that's what I thought. thanks.
Old 02-11-2014, 07:46 PM
Re: 4 eat autos
Careful about driving it with it in that condition, it can break the clutch hub off. It is an easy repair.
Old 02-13-2014, 06:28 PM
Re: 4 eat autos
Yea, I suffer every time I feel the kick on the back. I think I'll put the FWD fuse until external temp let me work on the car.
