Old 02-14-2022, 06:04 AM
gringo gringo is offline
After aceleration, cars turns off
Hi Guys,
My name is luiz, i´m from Brazil. My car After full aceleration the car turns off. No errors. What is it? Could you help me?
Old 02-14-2022, 06:38 PM
Trevor's Avatar
Trevor Trevor is offline
Re: After aceleration, cars turns off
Originally Posted by gringo View Post
Hi Guys,
If you mean, after holding the throttle pedal fully down, you should check the throttle position sensor/unit/indicator, full instructions have been posted here.
Trevor, New Zealand.
Old 02-14-2022, 07:02 PM
Originally Posted by Trevor View Post
If you mean, after holding the throttle pedal fully down, you should check the throttle position unit/indicator, full instructions have been posted here.
Thank you Trevor. That is it. After full throttle, when i leave the pedal the car tuns off. I´m going to find the the throttle position unit.
Regards
Old 02-14-2022, 07:14 PM
When the motor is cold, it´s not working well,I think it may be a correlation...
Old 02-14-2022, 07:28 PM
Is that good?
https://www.alibaba.com/product-deta...565364556.html
Old 02-14-2022, 07:59 PM
Trevor's Avatar
The engine should keep running at idle speed after any throttle position even when cold, when properly controlled by the electronics. Research here for posts covering idle setting and control problems for detailed information.
Old 02-15-2022, 02:49 PM
Dear,
My mechanic tested the voltage of the TPS, and it´s all right.
He is guessing that the problem is the Ignition Control module 3.3L J716 22438AA050, or the Crank Position Sensor.
What is your sugestion?
Old 02-15-2022, 03:35 PM
It doesn't sound like a crank position sensor issue. They usually cause a no start scenario.
Old 02-15-2022, 04:33 PM
The iddle speed is around 500 rpm when it´s cold, sometimes it´s turn off.
There is a atrong smell of cathalytic converter when it´s cold.
And the problem after full throttle, I leave the pedal and it turns off.
So sad.
Thank you guys.
Old 03-24-2022, 07:58 AM
Guys, I found the problem, it was the ignition module.
part number: J716 22438-AA050
Old 03-24-2022, 03:37 PM
Thanks for the update and solution.
