Air out dash vents
When i put my climet control on auto or any other position, I dont get any air out the dash vents. The air seems to work fine but all the air is below the dash. Nothing coming out the dash vents. I have checked to make sure they are open.. Any answers? Jim
heater/cooler air vents
Hi Jim, there was some discussion on heating/ cooling not to
long ago. For a/c I get air in the face from the vents. Here in the great white north we are experiencing -25 to -30 c at present and the hot air blows from the floor. I did try something when the SVX was nice and warm. I changed the temp. from 23 c to 20 c and what happened was this; the SVX called for cool outside air and it came through the vents on the dash. Hope this helps you........Ralph
RGG |
Well, seeing as how you're in AZ...
Do a search on the board for this topic. You'll find you can look to the right under the driver's footwell at the climate control levers that move to control the vents. One may appear to get stuck part of the way. You can move it by hand to free it, and apply some sort of grease or something to the track. |
Heat will not come out the dash vents. The engineers of the SVX designed the system NOT to blow out the vents. Heat is directed to the floor and a bit to through the windshield vents, but not to the dash. The reasoning (or so I've read) is that the Subaru engineers decided that the air, coming out of dash vents, dried the driver's eyes out. Since heat rises, they figured that the car would warm nicely without sending heat to the dash.
Hmm...I have been having the same problem! The no heat through dash vents idea is very logical though
1992 Pearlie ... ??????k Sold 8/04 Kenwood KDC-MPV619 Wedgie Cupholder 1998 Acura Integra LS 74k Sold 1/07 2007 Toyota Tacoma Prerunner SR5 .04k! 2011 Toyota Tacoma Double Cab, 4x4 TRD Sport |
paddlesnz 1993 Subaru Alcyone SVX 1980 Isuzu 117 Coupe Giugiaro Edition 1999 Mazda Astina 2006 Honda Legend 2006 Toyota Mark X Premium 2007 Toyota bB 2007 Mazda Roadster RS 2012 Peugeot 208 Allure |
air not heat
Its not the heat i am worried about. Its the air conditioning i am concerned about. I am in AZ and it does get HOT here... Thanks guys.. I will try to check under the dash for the control you are talking about..... Jim
Re: air not heat
Duh! Sorry, man, I'm spacin'. Either the actuator is getting weak, or the door is getting stiff. The actuator you'd be looking for is under the dash, on the driver's side of the tranny tunnel, just under the radio/cd player position. Shoot the linkage with a little silocone spray (I use WD 40 but have gotten hell for it, so I won't suggest it unless you're comfortable with the "bouquet" for a short period of time). If shooting the linkage doesn't do the trick, the actator may have gone south which is NOT an inexpensive fix, sorry to say.
thanks Randy,, will try that...... Jim
works now
Rabdy ,I just went out and looked under the dash and found the lever and moved it and it came un stuck.. Works fine now. Thanks again.....jim
Re: works now
Excellent! Welcome to "in your face" (pun intended) SVX fun!
