Erratic Idle Issue Solved!
I wrote in a couple of weeks ago with an erratic idle problem. After removing the intake manifold and replacing the PCV valve and then putting it all back together, my car was idling erratically (between 500 and 750 rpms) to the point where it would turn off. I checked all the hose connections, they looked fine. I rechecked everything, even removed and cleaned the idle adjustment valve. Nothing worked so I took it to a mechanic. They called shortly after I dropped it off and told me that I had leaks at both intake manifold gaskets and they needed to be replaced. I was able to order new ones for $30 and replace them in less than an hour (having now become intimately familiar with removing and reattaching the manifold - the mechanic wanted $450).
Well, that fixed the problem. The car now idles normally. Real happy about this - thought I did something that had caused irrevocable damage to the engine. Thought I'd write back and close the loop on this. Thanks. |
Re: Erratic Idle Issue Solved!
Ah! Another happy ending. Well done.
I had figured it would be something to do with the removal of the intake. |
Let this be a lesson to all... DO NOT REUSE GASKETS! its just not worth the headaches for a few bucks. This is in the top 5 of "repairs" made by owners that I have had to fix.
No offense intended, but honestly I am surprised that you thought you could reuse the gaskets, and then didn't suspect them when the problems started. (hindsight is 20/20 right)? I am glad that you have fixed now and that it did not turn out to be more serious.
No offense taken. I've never worked on the manifold before so didn't even think about replacing them as I was planning on replacing the PCV valve Now I know.
