crank pulley issues
What's up fellow SVXers?
I recently posted about having the serious electrical issues. Well, I've changed the alternator and all is well with the charging system, but I still need to find and kill my remaining electrical gremlins. Anyway, my lack of cruise, blinkers, and power door locks is no longer my concern. I've been driving my Jetta which doesn't compare to driving the SVX so even with the electrical issues I've felt the need to still drive my SVX occasionally. I took it to work last night and was at a stoplight when I heard a fairly nasty vibration coming from the engine. When I stopped to take a look I found the noise to be coming from the front of the engine and it would appear that my crank pulley is wobbling. Is this the case? I've already searched on the topic and found very little so please don't flame me. If this is the issue I have no reservations about changing it. My question is if anyone has heard anything about the Motorsport crank pulley. I figure if I'm gonna change it why not put on a lighter one and see if I can cut down on parasitic losses. Also, what's the easiest way to get the crank pulley off? I found in one of the posts that someone used a strap wrench and a breaker bar. Any other tricks I should know? Thanks in advance. Cheers, -Dave |
The Motorsport crank pulley would work fine and I think it is cheaper then a new OEM pulley. Just stay with a stock size pulley. I run lightened pulleys on both of my cars without any problems.
I've been running the Motorsport 1-piece OEM sized pulley with no troubles for a good while now, but some think it best to stick with the stock "harmonic balancer." (Gotta figure they made it that way for a reason.) Not to flame, but if you didn't specifically search "crank pulley," you should. I recall a few fairly detailed threads on the topic that could help you make an informed decision. Good luck.
dcb |
you could do what I did when my stock damper started "wobbling" --- find someone who had switched to an aftermarket damper and offer to buy their old stock damper
-Bill
I once found a place online called the "Damper Doctor" that quoted me a rebuild price considerably lower than the cost of new OEM, but of course, you have to send them your old pulley for a rebuild. They were in California. Google 'em and see what's what.
dcb |
if it's the same thing that happened to mine, the metal part of the damper is actually cracked. You'd have to weld it up and rebalance the unit. -Bill p.s. another option is dropping a PM on LAN and see if he can't cut you a stock sized damper, as he's got his equipment set up to do them in support of his s/c efforts
