Old 08-15-2018, 11:34 AM
Mrogan55 Mrogan55 is offline
Power Steering Question/Help
I need a power steering pressure switch. I found one at SSP Recycling, but they’re asking if I have engine speed sensor pump or electronic power steering pump. I have a 1992 SVX LS. Anybody have an idea?
Old 08-15-2018, 02:09 PM
SubaruPartsGirl SubaruPartsGirl is offline
Parts Hook-Up
Re: Power Steering Question/Help
My catalog lists a 1992 LS as having the engine speed sensing type and the LSL is electronically controlled.
Jackie
Annapolis Subaru
149 Old Solomon's Island Rd
Annapolis, MD 21401
443-837-1422
www.AnnapolisSubaru.com
Jackie.Whetzler@AnnapolisSubaru.com
Old 08-15-2018, 03:33 PM
SSP is an excellent company. I bought a whole rear sub-frame from them.
Old 08-30-2018, 10:42 AM
Jackie,
Would you know where I could buy the correct P/S pressure switch? The engine speed sensing type?
Much appreciated.
Mark
Old 08-30-2018, 11:30 AM
Parts Hook-Up
The part has been discontinued so you can no longer purchase it through a Subaru dealer. Even the pump is discontinued so that's not an option either. You can find a parts car or order a remanufactured unit from an aftermarket supplier. You might also try calling SVXFiles, he has a good selection of parts laying around. Best to call, he's hard to get ahold of electronically.
http://svxfiles.com/
Good luck!!!
Part number for the switch as a reference - 34428PA000
You might also try contacting the companies that rebuild them like AC Delco, Lares, A1 Cardone, they don't list the switch separately on Rock Auto!
Jackie
Annapolis Subaru
Annapolis, MD 21401
443-837-1422
Old 08-30-2018, 05:52 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Still available in Japan -
https://www.amayama.com/en/part/subaru/34428pa000
Old 09-04-2018, 06:37 AM
Parts Hook-Up
Thanks for the link, I'll be sure to save that site for later! Price isn't bad at all but I didn't fully check out to see what the shipping was.
Jackie
Annapolis Subaru
Annapolis, MD 21401
443-837-1422
Tags
