Old 06-08-2009, 09:21 AM
A/C Cool on the Feet but not much from the vents
My A\C seems so-so this year, I can tell it is cool, but not icy and also it only seems to blow on my feet, which is nice for my feet, but not so good for the rest of my body. Not to mention the people in the back seat.
So my question is should I be getting cool air out of the vents in the dash or does it only come out near the floor?
Also is it difficult/expensive to have someone to recharge it? I was reading a thread about conversion vs using the old stuff and it sounded like you could still find the old stuff but not easily. Any advice?
Old 06-08-2009, 09:48 AM
Re: A/C Cool on the Feet but not much from the vents
The motor/track that switches the air flow is probably gunked up and needs to be cleaned and reagreased to allow it to switch functions properly. On these cars, if it is on colder settings, it will always blow through the vents, and when set to warmer temps, it will always blow through the floor. That is the way it is designed.
Old 06-08-2009, 10:31 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Look next to your right leg on the center tunnel and you'll see a rod actuator on the side of the AC unit that slides in a track to switch the flow from dash to floor. You should see it move when you change the temp from heat to cool. Might be stuck, track fulll of dirt.
Gene
Gene and Ben
Old 06-08-2009, 12:16 PM
NiftySVX NiftySVX is offline
Send a message via AIM to NiftySVX
Run the self diagnostic by holding OFF and AUTO buttons while turning the ignition to on. If memory serves, the air mix door and other servos' positions are detected and any stuck servo will display an error code. An easy way to check the refrigerant charge is to run the a/c and watch the compressor, it should never cycle off. If it does, and there are no error codes, it is probably low on refrigerant. Don't have the system retrofitted if it needs recharging, call around until you can find a local shop that has R-12 on hand if you have a 1992 year model.
2007 GS 450h-Active Stabilizer/Radar cruise
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Toyota Master Diagnostic Technician (former life)
Old 06-08-2009, 12:21 PM
kwren's Avatar
kwren kwren is offline
Or maybe just take a quick look under there and see what is going on, like bwb3 said!
Keith
Old 06-08-2009, 01:56 PM
bwb3's Avatar
Post #6 has a photo of what I tried to describe http://www.subaru-svx.net/forum/show...ntrol+problems
Gene
Gene and Ben
Old 06-08-2009, 06:21 PM
Thumbs up Re: A/C Cool on the Feet but not much from the vents
You guys are awesome!!!!!!!!!!!!!!!!!! Score another one for the board.
After a cleaning the track my vents are now working.
Old 10-23-2009, 08:53 AM
Reviving an old thread here. My SVX is still having some issues going to the top vent, cleaning the track and lubricating it has not entirely corrected the issue. I basically have Floor and Defrost working, and dash vents I can only get working by manually moving the lever. Even then it won't stay there, it will slip back to the floor after the car has been turned off and restarted.
I can reach down and pull the lever until it goes into the position which engages the top vents, but it never does it on it's own. Also when I move it, I feel a lot of resistance until it pops beyond a certain point.
I was thinking I really need to take it off so that I can take a better look at the action of the mechanism and to check if something is broken or not. Has anybody removed or replaced one these levers, if so how much of a pain is it to get back on and into position?
Old 10-23-2009, 09:07 AM
redlightningsvx's Avatar
Collision Refinishing Tech
the solonoid may be bad which moves the leer.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-23-2009, 09:14 AM
Sometimes I hear it clicking when it is stuck so I think the solenoid is working.
