Power Windows/Moonroof Fuse/Relay!!!!
My power windows and moonroof stopped working. The power seats and locks are fine. I can't find a fuse or relay for either of these. Where should I look. I am getting frustrated fast!!
Michael 1994 Barcelona Red SVX-LSI Two-owner:169K 1995 Emerald Green SVX L AWD #80 - Custom intake w/cone filter 99K with killer stereo system 2002 Acura MDX-Touring Edition w/navigation 2008 Toyota Prius 1987 Mercedes Benz 560SL |
Fuse number 15 controls both the sunroof and the power windows. Its marked as "meter SRS Lamp" on your inside fuse panel. It's a 10 amp fuse.
I didn't mark it "meter SRS Lamp" so don't yell at me!!
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
Thanks, but I checked use #15 and it is fine.
I'll break out the service manual, and find the other incidentals. It'll take me a couple.
OK, typical troubleshooting here from the diagram in the FSM.
Fuse 15 feeds the actuator side of the Power window relay, with the real power to drive the windows etc., feeding straight off the Fusible link through the contact side of the PW relay. Both fuse 15 and the fusible link are hooked in series with the sunroof switch, and both come directly before them. Fuse 15 through the small filament/relay actuator side, and the fusible link feeding through both the PW circuit breaker, then the high amp side of relay, then on to the sunroof switch. That means it has to be either in the PW relay or PW circuit breaker since both systems are out on your car. The PW relay is underneith the driver's seat on a bracket along with the PW circuit breaker.
Thanks again. Is it true I have to remove the seat to get to them? What do I need to replace the relay.
