head unit help
so i'm having an issue....i want to put an aftermarket cd player, rockford head unit into the car, but there aren't brackets available for this? i can't find anything, anywhere, i've done advance auto parts, i've done walmart, i've done the car audio stores, nobody knows what to put in here.
am i missing something completely. any help? |
assuming it's a DIN/ISO unit (which I think all of the Rockford's are), the stock cage used in the SVX just bolts right up, no need for a kit. If you need a pocket on the bottom I think I used one from a late model Mustang (but you might want to check - basically a any DIN mount pocket will work).
i think the stock cage was removed with the stock head unit when he put a pioneer head unit.....or maybe he used it with that, but now i don't see that either.
frustrating. there's nothing out there for this damn car. |
In which case I'd go looking for the cage from someone parting out their car. There can't be that much call for a cage so I expect it wouldn't be hard to find. I know where two are in junk yards around me and all Subarus are a bit rare in FLA.
thanks, got all that, now i need the right wiring harness because apparently the one from the old car, isn't the right one for the new car.
i hate this crap, lol |
See my SVX Audio Installation Guide for pictures and everything you need to know. Quote:
Did the previous owner cut the SVX's stock radio plug? If so, then you need to decide whether you want to restore your SVX to stock and get a wiring adaptor (the mating plug that connects to it) -- recommended, or just hard-wire your new head unit's wiring harness in place of the Pioneer's. If you do the latter and ever want to change radios again, you'll have to mess with the wires inside your dash again. Compare what's in your car to the pictures in my guide. If your SVX now has something other than the stock radio plug or a Pioneer harness, send a picture and I can recommend what do to.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
okay, the stock is a 20 pin and that's what's in there, but i can't find a wiring harness that goes from that 20 pin to the damn radios head unit....the head unit is not a 20pin
so that's where i am. none of the car audio shops around here, or wal mart, autozone, vip, carquest, advanceautoparts, etc, none of them carry this f-in plug. any suggestions? |
Short answer: for a wiring adaptor that will plug into the SVX's stock radio harness, see this link:
http://www.subaru-svx.net/forum/showthread.php?t=6530 (that's the same link that soobiesvx93 posted above). There is also a link to that from my SVX Audio Installation Guide, which I gave a link to above. When I said that had "everything you need to know" I wasn't kidding . Not sure if you're aware of this, but in case not: Every different head unit manufacturer uses a different plug on the radio side. (Nearly) every different car manufacturer uses a different harness on the car side. You'll need two pieces to wire your new Rockford:
Read my guide. It's all in there!
i have the plug from the back of the rockford, i have the plug from the car, they don't match, i need a plug from one to the other.
that's where i'm at. i'll figure it out, thanks everyone |
