tweeter not functionning
Hi!
My tweeters is not working. When I purchased this SVX one year ago, the door speaker was destroyed. Could the tweeter have been also damaged? I have looked at the tweeter and they seem fine to me. What I can check next? The radio? Thanks! |
Given the way the door speakers dry out, it wouldn't surprise me if your tweeters have done the same. There are plenty of sources for replacements out there.
-Bill
How can I check if the tweeter get a signal from the radio? A voltmeter will work?
Try a multimeter - I'd check the resistance first to see if you've got an open or closed circuit.
-Bill
the OEM tweeters have the Xover at the tweeter itself, so the lines going to the door and to the tweeter (in the kickpanel) are full spectrum...so, got any other kind of speaker (like home stereo or computer) that you can plug into those lines & see if there's output. The reason I suggest this is a voltmeter response might be misleading given the wide frequency range and dynamics of typical music. If you don't have a speaker to use and want to use a voltmeter, then if you have a CD-burner, make a track with just one frequency (say 1000Hz) - that way at least the meter will have something stable to average.
yeah basically what lee said .........you won't get a standard "4 ohm" reading from the meter - actually it'll probably be extremely high ......you just have to test em out with another source that you know is outputting some juice.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Lee,
I understand what you're suggesting. Wouldn't the multimeter still tell him whether the circuit is open or closed? -Bill
