Lighting the grille
I'd like the light the clear part of my grille so it looks like it"s illuminated with a uniform-intensity bar of light with a brightness comparable to that of the low beam headlights. (not like the grilles of certain Mercurys & GM cars: it's obvious they're lit by individual, not to mention dim, bulbs.) Scouring the local autoparts stores (and some websits), a 20" white StreetGlow OPTX interior accent neon rod was the best prospect I could find. That leaves a gap in lighting of a few inches on either side, but the next size up I could find, 36" under-car neons, are way too long. When I tested the bulb out by plugging it into the cigarette lighter, I was disappointed by its low brightness. I've seen bars of LEDs spaced about an inch or so apart, but I'm afraid they'd look like the individual lights they really are.
DOES ANYONE HAVE ANY IDEAS? Are there bars of white LED's packed side-by-side? If so where can I find them? What if I'd use a household fuorescent tube fixture? What would I need to make that run of the correct voltage & amperage of an automotive electrical circuit? |
Re: Lighting the grille
There used to be something on one of the Japanese SVX websites a while back about how someone did this. They were using high-intensity 12v bulbs. Unfortunately it is not there any longer.
I have seen long strings of closely packed LED's on various websites (60-80 LEDS) but they are available only in red. But here is something I saved from that original Japanese SVX website. Click HERE
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-20-2004 at 12:10 PM. |
There is another car like that had a illuminated center "light". Its called a mercury...I don't even drive w/ the fog lights on for the sheer chance that some moron might mistake my car for a sable or some other peice of mercury crap. Or in simple terms, I think it would look like an early to mid 90's mercury.
We had a member ask a couple years ago what the little box with a dial in his passenger footwell was. When he turned the knob, it didn't seem to do anything. He figured out eventually that it was a controller for KITT-like lights in the grille.
Re: Re: Lighting the grille
1992 Pearlie ... ??????k Sold 8/04 Kenwood KDC-MPV619 Wedgie Cupholder 1998 Acura Integra LS 74k Sold 1/07 2007 Toyota Tacoma Prerunner SR5 .04k! 2011 Toyota Tacoma Double Cab, 4x4 TRD Sport |
http://www.subaru-svx.net/forum/show...&threadid=3617
phoenix96 2006 Legacy GT Limited · 2006 Outback 3.0R VDC · 1992 SVX LS-L
Check out the link landshark posted about the angel eyes in the lambo doors post... a similar thing would work pretty well i would think, and allow you to make an outline... i think it would be really cool if you did it with a full outline of the curved shape... anyone up to trying it??
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
...just thought I'd add a little something since you are still thinking about it.
The mercury deal was just bad all around, but when there is no stupid plastic things to break up the light it doesn't look too bad. In the end though I would probably go consistant.
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
just 12v 1156 bulbs, the install used replacement sockets for trailers, found em in a small autoparts store. You can also use replacement sockets/bulb holders for any car that uses 1156. Just drill the hole the size of the inner diameter, notch the "keyways" and install! A bit of high temp silicone (black of course) helps to weatherproof it and secure it in the hole.
hope that helps! ...the next step is to remove it
...and another
Check my locker if you like it. The final product of the one I have in there step by step gives an aggressive look.
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 02-16-2004 at 02:26 AM. |
Hmm... not too bad. Much nicer with the curves as opposed to the Mercury and Grand Prix that had the really square looking ones. I still prefer the '97 color matched grille, though. Wonder if KITT style LEDs would work along the edge of the solid colored grille?
-Aaron SVX: '92 Dark Teal 101k '97 Legacy GT Wagon: dead '99 Civic Si: daily driver... stolen and stripped with all my tools! '92 Yamaha FZR 600: garage 2011 Jetta: Daily disappointment |
Speedklix
It would help with your how to in your locker to include a file with directions and list the lights that you use.
electroluminsecent cable
www.streetglow.com they're good people i know a lot of people that have been going through them for modifying computer cases for years, they were one of the first companies to make EL cable available get it in white or yellow, the white will have a much more HID blue hue to it, the yellow might match the IC headlights better
SV What? |
