Newbe AWD Question
Hi there guys
Okay so as I understand it the normal operation of my car sends 90% of the power to the front and 10% to the rear. Personally I would rather have it the other way around as I much prefer rear wheel drive. So. 1) Is this correct? 2) How and when does the car send more power to the rear. 3) If I upgrade to a 5 speed WRX trans in the future does it operate the same way? 4) Does the car actually have some form of active torque distrubution or does it just sense slip via the ABS sensors. I am total noob here so any help would be appreciated. Thank in advance Tony |
1. Yes you are corect, the stock 4EAT has a 90/10 split. 2. It transfer up to 50/50 when the fronts slip. 3. The WRX 5MT is 50/50 all the time. The STi 6MT depending on the year is 35/65 w/o the DCCD hooked up (What I have) 4. As far as I know, we don't have the VTD set up on our rides. Hope that helps!
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
I always wondered if you could tap into that wire and adjust the signal it sends to PCM, any word on how you can trick the computer to give you 50/50 power? That would sure be nice for autocross!
1992 Teal LS-L w/ 150k miles bought March '06 ... stock |
