power steering return line
i just got finished replaceing my my return line. to stop the smoking from the leaking hose. and it still leaks onto the exhaust
1992 pearl svx (given away) Custom Cold Air Intake Stage1 Shift Kit Brembo Cross-Drilled/ Slotted Rotors. Front and Rear 4.44 gears now in better hands of svxfiles |
Did you get a new one or used? They tend to leak from the crimp if used.
no it is brand new
There are two return lines. One from the steering rack to the PS fluid cooler. (There actually is a cooler. It consists of a single u pipe.) The other return line goes from the cooler to the PS pump reservior. If you only replaced the line between the cooler and the PS pump reservior, then maybe the return line from the rack to the cooler is leaking badly. Might also be that the high pressure outlet on the PS pump is leaking. Fluid could leak down the front of the engine and onto the exhauset (and everything else under the car as the wind sprays it around).
Has it had time to burn off all the fluid thats already saturated your exhaust?
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
it has had time to burn off. about 4 hours of driving. it is the rubber hose from rack to the cooler. it is that one foot section of rubber hose above the exhaust. it was dry rotted and had holes in it
Universal hose is fine for the low pressure return lines.
Universal hose is fine as long as its rated for ATF.
Agree. I used universal ATF hose.
