WTF happened here?!
ok so i got a stock pulley from svxfiles and when i went to put it on i found out why mine was wobbling. the little slot the crank key slips into on the pulley has been gouged out to 3x it's original size and the key on the crankshaft is cocked sideways i just don't really know what would cause this to happen like this. i can't put the new pulley on because of the crank key being bent off to one side. i tried to get the key to straighten out but it's just not gonna happen. what am i gonna have to do to replace the key? i don't know how i'm gonna get the crank gear off with the key like that so i'm kinda screwed right now. this is my only day to work on it so some quick responses would be great. thanks guys, Jason
If you can take some pics as it'll help people trouble shoot your issue better...
-Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 09-27-2005 at 11:03 AM. |
That's a difficult problem to fix. I really hope that all goes well for you.
I think you may have to use a puller to get the pulley off the crank shaft. There could be problems with this method. The crank shaft could end up getting damaged if the key doesn't straighten out. Was the bolt loose? I think this damage could start if the bolt came loose. Another possibilityis the ac, ps, or alt siezing up and twisting the crank pulley. The belt would have to have been real tight for that to happen. Is the pulley loose on the crank shaft? If it is the shaft may be damaged.
i'll probally need a puller for the timing gear but the pulley comes right off. we figure either the bolt came loose at some point in it's life or like was said something froze up but those belts would have had to been plenty tight. but that is what kinda looks like happened though i'm gonna pull off the gear and find a new woodruff key and put on my new pulley and hopefully all will be well. i'll let you all know how things are going. i'll take pics when i get out there and get it all apart. wait till you see this
ok so heres some pics of the chaos. it's kinda hard to see but the key on the crankshaft is bent pretty good and you can see the great big opening in the pulley that should be no bigger than the crank key. this is gonna suck
That looks like one of the many things that happened with the Teg except my bolt was gone before the key was turned to dust replace the key and the pulley and hope that it didn't bugger the end of the crankshaft. also the pulley and key took all the damage on the Teg.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver Last edited by thundering02; 09-27-2005 at 06:24 PM. Reason: Spelling |
Don't have a clue got into the driveway for the battery to die(no alternator with no belt moving it) got uunder the hood the net morning to fing the bolt gone. no evidence it had been there for a while either the only thing I can even begin to think of is it came off some time after my father and I replaced the head(have to remove all the pulleys and even a motor mount to get the timeing belt cover off)
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I had the same problem and my belts actually let loose. Being close by I went to the dealer just running on the battery.
My ass still hurts from the raping but the guy did a good job. My pulley had the same keyway problem and he told me he had to pretty much make some ghetto key to hold the pulley on there. He also stated to make sure I always have that bolt torqued down to spec and spit me out the numbers. Of course if would help if he supplied me with the subaru tool to hold the dam pulley. Good guy though but oh the dealer sucks - I was pissed when I got the bill. Good luck
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
