Early shifting out of first gear.
So here's an annoying problem i've never encountered before. Our 94 svx, which has an almost new subaru reman tranny, will not hold first gear higher than 4500rpms. It shifts out if first gear at about 4500, even if I drop the shift selector to the "1" position. Any idea why? Everything else seems to be in good order as far as the transmission is concerned.
Mike |
bump? 67890
and that shift is out of first gear at 4500 all the time?
how about the other gears? they shifting out properly?
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
With your engine and transmission warmed up and the gear selector in top gear, if you put it into POWER mode, (rapid movement of accelerator pedal to the floor to light the POWER light) and keep it there in first gear, does it still shift at 4500 rpm or earlier?
It's normal for the transmission to upshift to 2nd with the gear selector in 1st to prevent damage to the transmission. It will also upshift to 3rd if the gear selector is in 2nd. Dan |
any chance you could put a Select Monitor on to see what the car is "telling you" when this happens? Have you run a trans diagnostic to see if any codes are hiding out?
-Bill
