Old 04-07-2005, 06:12 PM
svxash's Avatar
svxash svxash is offline
$21 spark plugs!!!????
I just called the parts store and the OE NGK stock #4014's are $20.99 a plug!! I went to the NGK web site http://www.ngksparkplugs.com/index2....000&country=US
and they also listed a stock#7092 as well. They are only $4.59 a plug. The 4014 is a Laser Platinum and the 7092 is a G-Power platinum. Is the Laser platinum that much better of a plug than the G-power platinum?
Old 04-07-2005, 06:21 PM
immortal_suby's Avatar
Thread Killah
If you get the right plug (the 4014) you will have another 100,000 miles to make up the difference in cost. From the description it seems the G-power only has platinum on the ground electrode, where the laser has platinum on the ground and center electrode.
Locker Link
2015 BRZ Limited 6MT
Old 04-07-2005, 06:23 PM
You should be able to find the OEM plugs for about $10. They list in Canada for CAD$24.00 each but I got them for CAD$16.00.
Keep looking for a better deal.
I quickly checked www.sparkplugs.com and the OEM plugs are $11.71
Old 04-07-2005, 07:46 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Go to: www.langstonspeed.com/
SVX spark plugs list for $8.25 each.
-Chike
P.S. Direct link is here: http://langstonspeed.com/proddetail....&CategoryID=19
2006 Steel Gray WRX TR (sold)
Old 04-08-2005, 12:15 PM
STORMINORMAN STORMINORMAN is offline
Lightbulb Well, they ARE a royal PITA to replace, but...
...I've had no problem at all with the regular Bosch Platinum plugs (@ $1.99 - rebate) which I change every 60K. They "read" normally, I have never experienced any kind of plug/ignition-related problem in almost 12 1/2 years and 120+K miles.
I have used the regular Champion Platinum plugs in other vehicles with very similiar success. The exception is a W126 Mercedes 420SEL V-8 which just seems to run and idle better with regular old Bosch copper core plugs: I'm told it has to do with the very design and nature of the entire ignition system.
Cheers!
p.s. Please remember to use the dielectric grease on the plug ends: it really helps!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
