auto window feature
Any helpful hints for hopeful heroes on this feature? The manual says to just push the button a little harder but i tried that and had no luck. I'm sure it's pilot error and not something wrong with the car. Any ideas? Thanks.
mmm, you need either to replace the master window switches or dismantle it and see where the problem lies...
Be careful not to push too hard on the button. You may break the screw that holds the switch assembly to the underside of the door panel......I've done that to my legacy about 3 times and it's a pain to fix.
The button should kind of click as you push it in for the auto down feature to work. If no click feel, then you need new switch. |
Someone correct me if I'm wrong, but 95 doesn't have auto up. Either that or it's been switched with one that doesn't have it. On switches with no auto up there is a tab that prevents the click.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 03-14-2007 at 05:17 PM. |
Auto Up was only available on the 92's. All other years were Auto Down only. Either way the feature works the same: use a little force on the switch and the window will move as long as you keep your finger on the switch. Move the switch until you feel a "click", and the window will move even after you take your finger away. Dave |
This is interesting. I have two '92 SVX's, both JDM. But in neither of them does the auto feature work. I have taken both door panels off and cannot see anything wrong with the switches, so I have just accepted that this is a mystery!
