S/C on the lil old slushbox?
Im looking seriously at the S/C's for sale currently. Unfortunately the cost *ugh* makes for sacrifices as well. I will certainly not be able to afford a M/T for quite some time if I get one of these S/Cs.
My auto runs perfectly strong, and has a cooler in the front. Is it going to blow up on me (spirited driving, but not abusive).
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Re: S/C on the lil old slushbox?
I had my AT for 5 months of very spirited driving and it held out just fine. It had been rebuilt about 45k prior though...
the slush box is limited in what it can handle on transferring power from the crank to the axles. It will fail, even sooner with a S/C.
Not a big problem tho, just figure out how to rebuild using a master transmission rebuild kit, do it yourself, not that expensive.....
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
it all depends on how "spirited" your driving will be, post s/c install
-Bill
it all depends on how hot the transmission gets. More power passing through the trans means the amount of heat it will generate will increase proportionally. Watch your temps. Otherwise weak points are.... Front diff, and trasnfer drum. Transfer drum will likely fail first shortly followed by the front diff case
Tom |
end of this thread will be by first the thread starter, posting FAIL of tranny. Fail
