Old 02-12-2012, 03:20 PM
whtrabbitjoe77 whtrabbitjoe77 is offline
quick transmission question 1-2 hard shift
When the car is cold the transmission will shift kind of hard from first to second. Once the car warms up the problem mostly goes away and under quicker acceleration the problem goes away. Could it be a simple fix like a band adjustment? Also for a car with higher mileage what type of aft are people running?
1997 Polo Green LSi #352 163,000 miles, let the rebuild begin!
Old 02-12-2012, 04:45 PM
Re: quick transmission question 1-2 hard shift
When the car is cold, does it do a hard shift from P to D?
Old 02-13-2012, 08:25 AM
Dont recall if it shifts hard from P to D, I can take the car out to night nad find out. It will shift slightly hard from P to R.
Old 02-13-2012, 07:47 PM
Yes it dose hard shift from P to D
Old 02-13-2012, 09:43 PM
OK its not the band.
If there is no Power light flashing a code 21, for the temp sensor, its the ATF is too thick, may be contaminated with diff oil?
Old 02-14-2012, 04:49 AM
michael's Avatar
michael michael is offline
What Potholes ???
Couldn't it also be the resistor near the battery?
Wanted: Steering Wheel
Old 02-14-2012, 02:40 PM
No, if it was the resistor, it would not come good when it warms up.
The TCU has a function that looks at the oil temp, and alters the line pressure to suit the colder oil. It would appear that the oil has a higher viscosity than the normal ATF, so the correction function, can't get the pressure to suit the oil.
The car is a OBD2 and I have no codes for the tranny. When I got the car I did a flush on the tranny and did not see any diff oil and I had then problem then. In 2 weeks I plan on dropping the pan and doing the fliter. what would be a good ATF to use?
I would like to do a 4.44 swap but to get the car inspected the exhaust has to be replaced.
Old 02-14-2012, 03:10 PM
I can't see any other reason for the pressure being high when it is cold. You would get a code if there was a fault in the 'correction' system.
I would use the ATF that Subaru recommends.
