how to change the O'ring on the transmission wiring harness
Does somebody knows how to remove the transmission wiring harnes on the picture so I can replace the O'ring signed with the number 4 on the page 86 of the following diagram? : http://www.phantomotaku.com/SVX/MSA5...fferential.pdf
please look at the pics thanks |
Re: how to change the O'ring on the transmission wiring harness
I don't know about anyone else, but that was a very slow download for me- this is the quick/dirty version:
I know on the newer cars that there is a bolt on a retainer and then the harness/connector pulls out, with the o ring on the connector. I *think* that is just in there with friction (clips in/squeeze and then pull like a pill bottle to get out), but I'm not home with my manuals. With the pic so people don't have to download 202MB, someone may chime in who knows for certain. |
I have never seen this with my own eyes, but I think that you need to compress the three "tangs" on the plastic part from the inside to release it.... and you need to install the new O-ring so that you pull the inside ends of the wires thru it...
So you might not be able to do it from the outside. Tapani |
When you go to remove the plastic clip from the inside of the transmission, expect the plastic to break.
I have never seen one that did not break. Just saying.
how to avoid oil leaks through that piont the simpliest way, without disassembling or braking anything? Last edited by THE NEW GUY; 02-13-2012 at 08:13 AM. |
"was it necesary to unlock something from inside or just pull it out from the outside?"
It has to be unlocked from the inside, and all that I have seen have become brittle over time and exposure to heat. However if you can clean the outside harness/case with brake cleaner you MIGHT be able to seal it with Permatex Right Stuff. (For example.)
can I ask you one more question? the tranny I boght is missing one "axle shaft" that locks inside one of the "differential bevel gear" inside the final front differential case. It's marked 120kgrams to pull it out, Do you have any methot to extract it so I can transfer it from my old tranny to the new one? |
thanks. I'll do it as soon as temp raise a little here in Montreal. |
Thread Tools | |
Display Modes | |
