Old 05-22-2008, 09:20 PM
theallpowerful theallpowerful is offline
Noobish trans thread
Hey guys, I recently got the SVX I bought for the 24hrs of Lemons race up and running (after re-installing the steering rack, amongst other things). When I drive around in drive it pulls fine (no slips), but when I let out of the throttle, it goes into neutral. I give it gas and it revs freely (in drive). It will then engage into gear on its own, and I can drive fine for a little while longer. Also, if I put it into 1st and second the trans works fine, no issues at all. Any ideas? I noticed the speedometer isnt working (are these trans dependent on any sort of speed-sensor input?) also clicking the manual button on the shifter causes no change.
car is a 92 LSL with 110k miles, Im going to service the trans next week ( i was going to anyway, just to prolong the inevitable).
closest thing I could find in the search was this:
http://www.subaru-svx.net/forum/show...s+shift&page=2
its close, but mine is not stalling
edit: I am reading more that if the thing behind the batt is unplugged something like this could happen, I will check that out in the morning.
Old 05-23-2008, 12:48 AM
This one is probably closer. Look at post 4.
http://www.subaru-svx.net/forum/showthread.php?t=44377
Old 05-23-2008, 10:27 AM
that is more like the problem, except mine will pull in drive but not if you let off of the gas. Anyway, it being a lemons car, a trans rebuild is out of budget. So I may just see how long she lasts in 1st and second gear only (what is top speed at redline in 2nd? my speedo doesnt work).
Old 05-23-2008, 04:50 PM
You should be able to drive it as I said in that thread, like this;
You can continue to drive it as you are doing, selecting 2nd with the shifter to start, then moving it to D to pick up 3rd. Of course you will have to select 2nd again when you slow down or stop.
