Old 05-03-2008, 08:15 AM
xthread xthread is offline
Question Door lock debug
Hi all,
The day before I bought my SVX the door lock were working. A couple days later, all I hear is a click sound (the relay called timer under dash passenger).
I removed the trim panel and saw that I got 12v at the actuator when the door lock/unlock button is pressed.
I tried unplugging the left actuator and the right one did not work. I did the same for right actuator, and no luck.
I removed the passenger actuator and put directly 12v across it. It did a spark but did not move.
Could both actuators be broken at the same time in a couple of days!?! How can I just open the actuator without breaking it?
Thanks
Old 05-03-2008, 09:02 AM
so both actuators are stuck?? what year is the car?? does it have a central locking button?
Old 05-03-2008, 10:15 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
You need to open up the lid of the actuator and look inside. Check for broken, bent or corroded contacts.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-03-2008, 01:58 PM
It is for a 95 with central door locking button.
I tried to pry the cover of the actuator without any luck. Any tricks?
Old 05-03-2008, 02:45 PM
b3lha's Avatar
Phil & Belha
Undo the screws that hold the lid on.
Old 05-07-2008, 06:45 PM
Yeah! I wish there was screws... Or maybe I just didn't look well!?!
Old 05-07-2008, 07:27 PM
there are small tabs on the center trim. Pry up but be careful not to break them
Old 05-07-2008, 08:22 PM
If you do end up needing a replacement:
http://www.subaru-svx.net/forum/showthread.php?t=44618
blk 92' LSL w/ average mods
