My car fixes itself...
sometimes!
Case 1: Last winter was my first winter with the car which had spent its life in TN and GA. When the weather got cold I noticed the idle would bounce a little when I started it. It would eventually settle but it would undershoot and overshoot the desired idle a couple of times. This happened more if the car had been driven a couple hours earlier versus sitting overnight but wouldn't happen if, say, I just stopped to get gas. Well, this winter the problem seems to be gone. I did get the valve cover gaskets and PCV changed late last winter/early spring. Regardless, somehow the problem seems to have fixed itself. Case 2: Yesterday the "Brake" light was on when I started the car in the morning and stayed on until I got to work. I never use the emergency brake, as I rarely park on a steep incline, and it still seems tight. When I got to work I turned into my parking space (right turn) and the light went off and stayed off. Now, if only the rattle noise in the front would fix itself and stayed fixed, as well as the #3 O2 sensor that comes on about once every 3-4 months.
Re: My car fixes itself...
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
mine fixes itself too!!
every once in a while my check engine light will come on for no apparent reason then it will shut off either by itself or when i shut the car off and turn it back on! these cars are special
Jared 1992 dark teal SVX LS |
#3 o2 sensor? I was under the impression the SVX only had 2 of them
Why #3 O2 sensor? Because OBD-II.
'92 SVX LS Pearl White - 6mt |
1992 Subaru SVX LS-L Pearlie 1989 Mazda RX7 2005 Mini Cooper S |
How does that "ignore" feature work again?
OR, because your reservoir cap is "f---t up!
When it is real cold my engine light will come on when i start the car up and rev up and down and will die. It hasnt done it for a while now but the last time it did it I reved it real high and it went off and hasnt been back on or run erratic. My codes when the light was on was for the bypass control valve and 2 o2 sensors. I think maybe it had something gummed up in a vacuum line maybe and the rev blew it out.
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS |
OK I'll play, my pearle has a check engine light after a drive and shut down then restart, but if I pop the hood after a drive and "check the engine" then no light. Then the other day went for a drive and the only part of my front wiper switch that worked was mist, where you pull it forward for 1 swipe, oh great I thought, now we are a fair weather car! After driving for awhile I turned to the high setting and left it there, bingo started working correctly. Ya these cars are SPECIAL alright......G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
Does the pregnant master cylinder cap need to be replaced or is it ok to just "pop" it back down?
Ok to pop it back down. The bellows helps keeps moisture absorption by the brake fluid down.(when it is working correctly)
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
