complete gasket kit
Might do a engine refresh. So is there a complete engine gasket set available?
Re: complete gasket kit
Yes there is.
Ok where can I find it and how much ? Is it a complete kit ?
$259.29 subaruparts.com It seems very complete.
01 $259.29 Gasket&seal kit-eng 02 $1.53 Gskt-28.2x33.5x1 03 $1.52 Gskt-28.2x33.5x2 04 $1.72 Gskt-36.2x44x1.5 05 $9.45 Oilseal-86x103x1 06 $2.42 O ring-19.2x2.4 07 $2.51 O ring-31x2.0 08 $3.12 O ring-32.6x2.7 09 $3.33 Wash-cylinder blk sl 10 $39.56 Gskt-cylinder head 11 $1.35 O ring-8.8x1.9 12 $0.65 O ring-10x2 13 $1.48 O ring-21.8x2.4 14 $11.58 Clng-oil pan 15 $0.79 Gskt-drain plug 16 $0.49 Circlip-inr 23 17 $6.35 Oilseal-32x45x8 18 $3.66 Plug-45x8 19 $5.82 Sealing-tension 20 $16.96 Slng-belt cvr, 2 21 $10.32 Slng-belt cvr, 2 22 $15.34 Slng-belt cvr, 2 23 $15.34 Slng-belt cvr 24 $3.47 Seal-int valve 25 $3.92 Seal-exh valve 26 $4.44 Gskt-oil sepr cvr 27 $2.48 Gskt-oil sepr cvr 28 $13.42 Gskt-roc cvr right hand 29 $2.84 Wash-rocker cover 30 $13.42 Gskt-roc cvr left hand 31 $6.30 Gskt-roc cvr, 2 32 $6.30 Gskt-roc cvr, 2 33 $6.30 Gskt-rocker cover 34 $6.30 Gskt-rocker cover 35 $11.54 Gskt-int manif 36 $6.98 Gskt-int coll 37 $8.82 Gskt-exh manif 38 $0.92 Gskt-10x14x1 39 $3.97 Gskt-egr cont 40 $8.66 Gskt-egr cont 41 $6.78 Oilseal-33x49x8 42 $1.45 Sealing-oil pump 43 $1.45 Sealing-oil pump 44 $2.76 O ring-23.7x3.5 45 $5.82 Gskt-throt chmb 46 $4.66 Gskt-air cont 47 $0.91 O ring-fuel pipe 48 $3.04 Gasket-water 49 $2.77 Sealing-water pmp 50 $1.17 O ring-13x2.4 51 $1.41 O ring-37.7x3.5 |
Thank you blacky didn't mean to.sound like a smart ass
I did actually.
Subaru has a full engine reseal kit... includes most of the main seals and gaskets:
From subaruparts.com: Subaru part #: 10105AA060 - Engine Gasket/seal K - List: $327.38 Price: $259.29 |
Let's keep this thread going!
Subaruparts.com sells the gasket set. The part number is 10105AA060 and it costs $259.29.
Just note that it does NOT include rings or bearings.
Or vacuum lines, or PCV valve. Or knock sensors, or IRIS valve. Or broken relays or old sensors.
I added my post because there was no mention of the part number for the gasket set and it has been pretty hard to dig up on subaruparts.com.
