Old 07-20-2004, 08:34 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Recommendations for ATF and Diff fluid?
I'm doing my trans and diff swap this Friday, and wanted to know what recommendations people have.
I'm not looking to use synthetic fluids, but want opinions on the regular fluids I can pick up from my local Autoparts Store (Advanced, Autozone, etc.)
Thanks!
-Chike
2006 Steel Gray WRX TR (sold)
Old 07-20-2004, 09:55 AM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
If you do a search there is an array of opinions. Trust me. I'm still confused and looking for ideas...
-Mike
Old 07-20-2004, 10:27 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chike,
I just picked up some of the Lucas 80/90 diff fluid at Advanced Auto. They only had one bottle, so I have to drop by again tonight to get 2 more (not having checked the shop manual to see exactly how much fluid the diff holds...)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-20-2004, 10:33 AM
Chiketkd's Avatar
Thanks Bill. I'll be picking my fluids up on Thursday. So Lucas 80/90 for the diff. What do your recommend for the ATF? Valvoline?
-Chike
Originally posted by SVXRide
Chike,
-Bill
Old 07-20-2004, 10:53 AM
SVXRide's Avatar
Chike,
The Lucas diff fluid says it's good for LSDs and I've had good success with their oil additive.
ATF fluid -- I've flushed all the synth out of my trans! I'm now using Valvoline ATF for high mileage transmissions....
-Bill
Old 07-20-2004, 11:06 AM
Chiketkd's Avatar
Awesome. I'll pick that up as well...
-Chike
-Bill
Old 07-20-2004, 11:15 AM
Whoru465's Avatar
The name's...
Relevant question?
While I'm thinking, might I ask you guys how many quarts of ATF the tranny takes? I am still without a manual. Thanks.
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 07-20-2004, 11:31 AM
Chiketkd's Avatar
If I remember correctly, the 4EAT takes about 10 quarts of ATF. However, if you drain it, you'll probably only need to replace about 6-7 quarts.
-Chike
Old 07-20-2004, 11:36 AM
Whoru465's Avatar
The name's...
Thanks
-Mike
That's right...
Old 07-20-2004, 11:37 AM
dcarrb dcarrb is offline
Don't over do it...
Actually, the pan doesn't quite hold four quarts, as I recall. Just measure what you drain and refill with that amount, assuming your transmission is properly filled.
dcb
Old 07-20-2004, 12:11 PM
Chiketkd's Avatar
Re: Don't over do it...
Yes, the pan holds ~4 quarts, but the entire trans will have about 10. If you drain the trans for only 10 minutes, you'll probably only collect about 4 qts, but if you let it drain for a good 1/2 hour, 6-7 qts should be collected.
-Chike
P.S. It's always a good idea to put back the same amount of ATF that you drained out.
dcb
Old 07-20-2004, 12:41 PM
Bobb Bobb is offline
Fluid
Hi Chike, I've used Mobil 1 ATF in my trans since it was replaced a couple of years ago. At the same time I replaced the diff's fluid with Mobil 1 diff juice. As for engine oil I've gone over to max/high milage oil. One of which now has synthetic. I don't remember whom it was. I think as long as you use a high quality product you will be okay. Take care and happy draining. BOBB
P/S In the owners manual it says not to use 5-30 oil if you drive a lot of hi-speed miles. However this was based on oil that was available 14 or 15 years ago, so it may not still hold true. "B"
Old 07-21-2004, 06:20 AM
owner's manual specs
Transmission spec per the owner's manual: capacity 10 quarts U.S.; drain/refill 2.6 to 3.2 quarts.
dcb
Old 07-21-2004, 07:46 AM
Oil Capacity
The front diff holds 1.3 us quarts,
the rear diff holds .8 us quarts.
Mobile 1 synthetic is only $8.82 a quart at my local Advance store. I went with that, it's cheap insurance. Tom
ps; the book does say 10 us quarts in the trans. Dextron 2.
Old 07-21-2004, 11:15 AM
ATF
Hi everyone, Dextron 2 has been upgraded to Dextron 3. It is backwards compatible so have fun,and take care, BOBB
