Well, here's what I'm thinking:
The stage 3 project yielded some great developments for svx tuning but at the same time it took a lot longer than planned and a lot more resources and consequently a lot of money out of my pocket. In the end I got left without a blower or fuel injectors, a blown transmission, and a hurting on my bank accounts. I'll even go out on a limb and guess that my dissatisfaction with the current situation is probably pretty apparent in my recent lack of humor and patience with comments regarding my spending more money on dyno time. That leaves me with the question of how to make back my money as quickly as possible, get my driveline back in order, and get the next generation of stage 3 on it. Now I'm trying to answer that question by asking the same questions I did back before I got into stage 3: What can I make that you want to buy? What do you want to pay for it? I'm always listening for that information so I think I have a pretty good idea but hey I'm just going to ask to make sure. My thoughts are that I should: 1) Update stage 1 to run a full throttle afr between 12.5 and 12.9 and move the agressive timing table with the fix for the mt stall problem to it, the second set of code still being for regular unleaded. 2)Update the stage 2 software to use 370cc injectors which are available for cheap and make it capable of handling 400hp. The first set of code on the adaptor still able to run all grades of gasoline and the 2nd set of code on the adaptor for E85. My assumption here is that everyone willing to pay for stage 2 to be able to use the z32maf meter would be willing to pay the $150 more it would cost them to get the fuel injectors on ebay. My hopes are that those offerings are exciting enough that the # of people who would immediately purchase the updates will if not make me my money back from stage 3 at least give me the funds to get my car trans and support the next evolution of stage 3 development (which has been continueing privately). Are my thoughts and assumptions right? What would you like to pay to upgrade from whichever you have now to whichever new version you would want? |
Comments: 1. Every SVX in existence should have the revised/refined Stage 1 you're proposing! 2. The revised Stage 2 looking interesting - will the 370cc injectors be "plug'n'play" in our stock rails? Will the timing table be even more "aggresive" than the revised Stage 1? What duty cycle would you see the 370s running at (85%?)? Since 300cc/min should - theoretically - support around 360hp, the 370s would give us even more headroom to work with Any chance that this software will be an "evolution" of the "G" software Tom is now running? I'd definitely want to check out the revised Stage 2 in BillStock v4.0 (with fresh engine) and the Stage 1 in BillStock v1.0 -Bill
Bill, yes the stage 2 software I am proposing should be seen as the replacement of the G version of the stage 3 software prototype we have settled on. It will be the same software except with 370cc injectors. The 6 current stage 3 owners will be the only recipients of the current stage 3 software. The current stage 3 software is just a stepping stone in my future stage 3 plans. The 370cc injectors are sufficient to keep up with z32maf meter and the new stage 2 software will be able to meet the needs of those doing their own forced induction.
The stage 3 software will continue to not be available separate from the stage 3 kit and it will be changed for dual intakes in which the z32 meter will only measure the airflow of one intake. With this set up the stage 3 software will be able to handle 1000hp.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 11-20-2006 at 09:15 PM. |
So, fuel management and even more "aggressive" timing than the revised Stage 1, right? Sign me up as long as the 370 cc injectors are "plug-n-play" with our fuel rails! -Bill p.s. are all 6 Stage III owners running the 740 cc NISMO injectors?
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 11-20-2006 at 11:41 PM. |
perfect... I was talking to Phil about a dual intake today. How soon do u want to test it out?? I will be fabbing up my new intake this winter and If you want to go dual, this will allow me to follow my asperations
Tom |
One of the mods want to grab the end of this thread from post #172 and make a new one with it?
Question about the dual intake:
What happens if there is a unexspected restriction on the metered side. Couldn't you potentially run lean and blow your motor? For that matter how are you going to garentee you even have equal flow on each side in the first place? |
Adding the fix for the mt stall in the stage one would be nice. I know that I would be willing to pay around $50 for a software upgrade to fix the stall.
I have not finish my 5 speed swap yet, but I don't want a stall after the swap. I was going to get stage 2 at some point, but on a college student budget that will not happen for some time. Bigger injectors for stage 2 seems only logical to me. Engine and fuel management in one package.
I'd still be in.
Mike,
I'm interested in the new Stage 2. New S1, S2 and S3 are well thought, covering the spectrum of all possible need. Quote:
The stage 2 proved able to run aggressive timing with all grades of gasoline already. Without the z32 meter the stage 1 software may not want to run as aggressive timing with regular unleaded; then again we might get away with running all grades on the 1st. Since it sounds like that is what people want for stage 1 I'll make that software right now and start driving on it with regular to see. I was just figuring to continue making the 2nd set of code have less timing just in case and in case you want to run nitrous.
Is there something else you'd like to put on the 2nd set of code or were you just not seeing the logic? Quote:
I wasn't following how the proposed S2 could run all grades with lots of timing, while the newly proposed S1 wouldn't run all grades [regular] with lots of timing? It has to do with the Z32meter? Fuel programming? Just not tested yet?
The second set of code for S1 with less timing is good for stock displacement 4EAT's running nitrous, regular fuel, higher compression, etc., correct? You said you will test the new first set of code for S1 with regular fuel. Will the S1 programming reduce timing via knock sensors on regular fuel, or do you expect the programming to run optimal timing running regular fuel; the same advance curve running premium? The factory programming has less timing, but doesn't really like regular fuel. The reason your programming can run MORE TIMING on LESS OCTANE has to do with the fuel programming changes you have made? Quote:
I had a question, and maybe this is dumb, but will the chip allow running 100+ octane race fuel? I've read that various racing fuels contain lead, and I understand that might cause a problem, but I don't know why exactly. Can anyone explain it?
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* Last edited by Nemesis Destiny; 11-25-2006 at 12:33 AM. |
It doesn't take too many tank fulls, to coat the catalytic converters, rendering them non working, and to coat the plug insulators. With lead on the plugs, you can't run the very high voltages, with lean cruise mixtures, they misfire. Don't know about the chip? Harvey.
