#46
Re: EGR
Also, I added more stuff to my last post, FYI
#47
Re: EGR
I guess it's more worthwhile for turbocharged engines to remove it than NA because of the loss of exhaust through the EGR at high rpms; ie more exhaust flow = more boost. I'm ok with it lowering engine temps. These engines are too damn hot as it is. I have to wait at least 2 hours before working on it unless I point an industrial fan at it on full speed for 20 minutes. By the way, here's some fun facts since you mentioned the products of combustion: the best performing liquid rocket fuel creates pure water, and the most common solid rocket fuel is aluminum and tire rubber blended together. I inb4'd! Your statement is invalid!
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#48
Re: EGR
Relocating them is a good idea I thought about it but did not, though with the ceramic coating on the intake I suspect they wont get quite as hot. As to the header tube going up to the egr I plugged it at the top, I too was unable to get the tube out of the header. I used some high temp rtv and a block plate, bolt and nut on the flange of the tube. If I take the engine out, or at least the header i will try a flare nut wrench on it, seems that might be the easiest, oh and torching it may help too. |
#49
Re: EGR
Or I was also thinking I could grid the tube off at the nut, and then drill and tap the hole and still put a bolt in it.
#50
Re: EGR
So icing, should I still go ahead with trying the seafoam in there?
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
#51
Re: EGR
Go ahead and try it if you feel comfortable doing so. I didn't have any seafoam at home like I thought, so I couldn't try it on mine, sorry.
#52
Re: EGR
Bringing this old thread from the archives!
did anyone try sucking in Seafoam through the vac hose that is connected to the "P" nipple of the intake manifold as suggested earlier in this thread? There might be not enough vacuum to suck in Seafoam was something that was mentioned. Thanks.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
