Radio compatability
I have a 1992 JDM car with radio and CD player as originally fitted. I need to do something as the radio can only currently pick up Radio 2!. So, I can either have a converter fitted, or I can throw it all away and have the whole radio assembly replaced with a newer Radio/CD player. However, I was wondering whether a UK fit radio would be suitable and, if so, does the UK radio have RDS? If so, I will search the network and e-bay to find one. Any advice?
I had a Sony radio cassette unit fitted (single DIN) with a 6 cd changer in the boot. I think everyone will also recommend changing the standard-fit speakers for aftermarket - you won't be disappointed! Do a search on radio or the lockers and you will find some excellent removal/fitting instructions
Hi Blackbird,
I have the original radio with a signal converter fitted on one aerial and the other one unplugged. It works fine except I don't get the full UK range of signals. The Japanese radio can receive signal between 76 and 90 MHz. My converter can be set to shift it by 10 or 20 Mhz. Thus the radio picks up stations from 86 to 100 (if set to shift by 10) or 96 to 110 (if set to shift by 20). We kept the factory system because we like the buttons on the steering wheel. Unless you feel the same then the converter idea is a nuisance. Do you have the single slot CD player or the 12 disk boot-mounted changer? Some people on this site have installed the double DIN subaru stereo from the impreza, which looks quite tidy. I assume that would have RDS. Certainly the single DIN unit in my Legacy does. (But I don't like RDS so I switch it off). I agree with Tony that it's definitely worth replacing the speakers. Phil. |
Phil,
It would seem that putting the frequency shifter in doesn't help a great deal as the frequency range of the radio would still be limited. I can't remember the actual frequencies but I think I listen to a range between about 86 (Radio 4) and 101 (Classic FM). If I rule out that route, then I need to replace the radio as I don't have the advantage of the buttons on the wheel as you do. I thought mind had all the toys including 4WS and Auto headlamps, but clearly there are some bits such as seat warmers and radio controls on the steering wheel that I am missing. The CD player is the 12-stack Panasonic box in the boot, with the controller taking up the bottom half of the double din space in the console.If a UK radio would give me the frequency cover I want (a given) and offered me RDS which I really want as I hate having to chase frequencies as I drive around the country (Traffic announcements always turned off as they drive me mad), then that would be my favoured option. Perhaps someone else could advise on that. If that doesn't work, then I will try and find a single DIN radio with inbuild CD control that will interface to the existing Panasonic device in the boot. If that fails, I will just go for a Radio/single CD player and put the rest on e-Bay! |
I saw a posting somewhere which said that the SVX CD Changer could be controlled by the Single DIN Subaru/Panasonic units fitted to the Legacy. I haven't investigated any further but if so then it would give you the frequencies you want and RDS.
There is a company which sells an adapter to interface a Sony or Alpine CD Changer to a Panasonic head unit. Presumably it could also be done the other way around. Unfortunately my CD changer is broken, please let me know if you decide to sell yours. Phil. |
Thanks Phil. I will give this thread another couple of days to run to see what other advice there may be before making any decisions. I will also talk to the friendly local car radio guy to see what he suggests as well. Once I have decided I will let you know and if I do decide to get rid of the CD changer I will certainly let you know.
On a separate issue you may not have seen my other thread about the central locking. Have you done anything to disable the speed sensitive locking on your car, or do you just live with the need to to unlock it every time from the driver's door? Dave |
CD Changer
Lars
lars s |
That's interesting Dave. Up to now, Phil & Belha's car is the only one I am aware of inthe UK that has the top spec, with the 4WS. Does your chassis number start with CXD or CXW? I imagine if you do not have the radio buttons on the wheel, this might indicate you have an airbag equipped wheel. They are mutually exclusive, don't want to be picking radio control buttons out of your teeth. Be interesting to compare spec. Yours being Japanese will have the plastic headlamps, not glass, as for Europe. This will mean you have the bonus of the extra foglamp the glass ones don't get, but you will not have the headlamp washer. Not sure if plastic lights ever got the headlamp levelling, Phil, has yours got it? Joe
Hi Joe, I've seen another 4WS in the UK. Identical to ours but in the silver two-tone Tony colour scheme. If Dave also has one then that makes three. We don't have headlamp levelling, I think that's Euro only. Same with the seat warmers. We have got the auto "turn on when it gets dark" headlamps, which flash the car in front everytime you pass under a motorway gantry. Phil. |
Radio Gaga
I've got 2 UK spec Radio/Cassettes and 1 boot 12 CD changer that I have taken out - so, if you are interested make me an offer.
MessengerO |
Does the UK spec radio come with RDS? Does it take up the full double DIN space?
Radio
I think iit has RDS EON TP etc etc, but I can't confirm that till I am in London early next week. All I know is both my cars are UK spec, both had the same double DIN item, and both radios worked until I removed them. also have decent Sony CD/Radio with wired remote that I would sell on. Will post info when I check it.
Messenger0 |
Happy to wait until you can check. I would probably be looking for the CD unit as well as mine is fine if the car is static but skips as soon as the car moves!
Dave |
The tuner I have in the double din setup [tuner/tape above, single CD below] does not have any of the fancy tuner features, RDS, EON, TPS any of that fancy tuner stuff.
On the other hand, the single din unit in the UK car has so many features, the owner's manual has about 20 pages on it. Due to the age of them, they may skip a bit over bumps etc. This could be due to there being a very small or non-existent buffer in the CD units. Big buffers were not common in 91/92. If it's doing it a lot, then you need to use a "cleaner" disk, or some other means of cleaning the laser head. If it can't "see" properly due to dust and fluff, the software will make it jump about a lot. Worth trying to clean it to see what improvement you make. Joe
