#31
i d it, if it works well what's the problem with it?
92 LS-L been sitting for 6 years. 86 fiero gt, t-tops, 3800sc, headers, intercooler, p&p blower and lower intake, 3.0 pulley, 1.6RR's, double roller timing chain, xp cam, 130lb valve springs and hooisers :P 87 starion- currently rides on jackstands. |
#32
is that anything like the kung fu grip? i d it as well. why is it a bad choice? Last edited by Matthewmongan; 11-29-2005 at 05:32 AM. |
#33
In our case, it is probably when you are fitting the differential, it get stuck somewhere, and you use a Kung Fu technique called Phantom Grip setting it in place... No need to it anymore guys, this is it
#34
