Claret: Improvements!
I had originally thought that this thread would be destined for a separate sub-forum, but there are so many things going on with my car at present, that I feel it's better suited in General for the time being.
Abridged story: With the shop closing, and with school and other things looming in my future, I parted ways with my Ebony 92 and some other things, and decided to concentrate on my Claret, to which I have made significant investments. Backstory: I am the third owner of this car (since August 2005) and had purchased it from a forum member in Vermont, who had it for roughly two years after purchasing it from the original owner on Long Island, NY. That in mind, there were some concerns regarding the car's city life and some time spent up north. My exterior, interior, and other reconditioning/restoration projects have significantly improved the car, overall. To: Fast forward: Several things going on at once led to me putting this car into daily use for a brief few months, and after that time, the motor and transmission were both showing signs that they were both not going to be around much longer. Oversight during my rebuild (ultimately resulting in engine failure) and an unknown mileage front differential, and a bad sense of timing, were all in play here. Finally I was able to crack into this project again full-force over the past few weeks Thanks Tom for the push and help :P The engine and trans for a rebuilt long block and a 5 speed conversion. With the closing of the shop rapidly approaching, I figured I'd take one last swing at the "might-as-well-get-it-done-while it's apart" items. -Rebuilt Long Block -5-Speed Transmission (4.11) -Install 4.11 Rear -Reinstall Air Conditioning -New Fuel Lines above tank -New Rear Brake Lines (Hard lines were rusted and fell apart when I unclipped them) -Powdercoated 5-speed Crossmember -Whiteline Urethane Differential Bushings -Refinish Subframe and Brace and all brackets -Install Bullet Cat-Back Exhaust and new gaskets and hardware on Catalytic Converter -Stainless Brake Lines all around -New Rear Rotors and Pads -STi Group N Motor & Trans Mounts -New Throttle and Clutch Cable from Subaru -Resurfaced Flywheel -Reinstall Prodrive PFF-7s with my Proxes4 's back on them. I have to pick up a few more minor things (new tank straps, iris check valve, and a pcv hose) and I should be able to tackle the rest of the project on Wednesday night and Saturday. I will post some photos in a moment.
1991 SVX L JDM |
Re: Claret: Improvements!
Glad to see you were able to get the project done. Looks good, I can't wait to have my very own 5spd hehe.
I know that feeling.....
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
Definitely nice looking there Mike. And when did Eric hit puberty? I noticed he has facial hair there.
Congratulations, Eric!
Back in the driver's seat!
Many thanks to Tom for helping me out. I appreciate it, big time.
1991 SVX L JDM |
Old engine coming out:
Drivetrain: Out Short Block: New engine almost back together: Box of new stuff: Subframe and tank ready to go back in.
1991 SVX L JDM |
Currently the car is on the lift, and waiting for the arrival of a few small parts so that it all can go back into the car.
1991 SVX L JDM |
Looks Great Mike. Are those the whiteline rear diff inserts or full bushing on your rear cross member? Will you be doing the adjustable lateral links as well? Engine is looking pretty clean too.
Thanks Seth. Those are the same WL inserts you had used in your car. I am holding off on links for now, but they could be in the future, perhaps when its time for coilovers...
1991 SVX L JDM Last edited by Mike621; 02-15-2010 at 08:43 PM. |
Mike,
Looks good! Is the 5 spd one of the "brand new" ones? If it is, remember that they're 3.90s not 4.11s -Bill
1.) Straight Stock 2.) Earthworms full bushings 3.) Whiteline inserts So getting your thoughts on them will help to determine how worthwhile they would be as a cheaper easier alternative. Still with all the powder coated parts and cleaned up subframes new exhaust (cant wait to hear what you think on the bullet set up either) brake hardware, it will be good to get your over all impression when it is done. Then you can work towards the Bontrager Works Sway bar and the links! |
