Brake band adjusting
I'm adjusting my brake band, as per the instructions in the how-to. They state "tighten adjust screw, the back off 3 turns." Which way is tight? Right would be decreasing clearance, and left is tighter clearance. Do I increase clearance to tighten it down? I don't want the band strut to fall off inside the tranny by turning it the wrong way.
-Nate '92 LS-L Pearlie |
I adjusted it all the way out for tighter clearance, and it hits second gear for just a half second and then falls into 3rd. I guess the brake band is gone shot.
-Nate '92 LS-L Pearlie Last edited by Sir. Nate; 02-24-2008 at 04:10 PM. |
clockwise = tight
you want to decrease clearance to tighten it down. too loose allows shifting straight from 1st to 3rd - as you are experiencing.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 02-25-2008 at 04:01 PM. |
okay, I adjusted the brake band all the way in and it works now, but it's worn out pretty bad.
