:( my engine just blew
and i just got my car back from the dealership yesterday...I was driving back home and the car wouldnt shift out of first and then just turned off, and now makes a horrible horrible sound...sounds like you can hear the piston going up and down almost...I checked the oil, and there was none at all...When i left in the afternoon yesterday i checked the oil and it was perfect...I cant even tell you how mad i am right now, i really hope they plan on getting me a new engine and not screwing me around here...sorry just had to vent...
Sorry to hear this....Have you called them and told them yet???
Re: :( my engine just blew
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
they better get you a new engine....that is murder!
Kelli
Previous owner of the Princess Pearlie "Dimples" as of 8/6/03 1992 LS-L Pearl 124k "Yeah, that thingy!" owner of the new 1992 LS-L Pearl "Susie" I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy. |
it went in for the cam , crank, valve cover seals and a waterpump...then the night i picked it up i saw it was leaving a spot of oil, so the next day (yesterday afternoon) i went to the dealership and asked them what was going on since i just had the seals fixed...they said it was just the steering rack so i went on my way and didnt bother to worry about the car at all...i checked the oil before i left to go to the dealership and it was perfect later that same night is when the catastrophe happend
Humm, doing those repairs woulden't require the oil to be drained. Ck your reciept, see if they charged out oil and possibly a filter. A lot of dealerships will change the oil as part of a job like yours because of getting pieces of gasket debris in the system. If they did change the oil then I would say they are on the hook (their insurance).
If I were you I would begin my own search for a good used engine. Otherwise the insurance adjuster will, and he won't care where it comes from OR ask important questions like you would. I've worked in dealerships or in the car business most of my life. The insurance company will look out for themselves before you I'm afraid. GOOD LUCK!! Scott Omaha PS don't let them "fix" the old engine. Make them put in a different one. Once the engine has been oil starved its a done deal. |
ok so i just got home from the dealer and he said they think it is the timing belt tensioner??thats whats making the god awful noise...His reasoning for oil not being existant on the dip stick right after it happend was: "the svx oil pan is xtremely small and right after you turn the car off the oil is still out of the pan, so you have to wait for the oil to drain back down to see if there is oil in it.." is that correct???every other car i've owned you could check the oil right after you were done driving....Is this a major problem???did it do any significant damage to engine being run for aprox. 30 sec...they are gonna know tomorrow when they take the cover off then they'll tell me...i have a bad feeling they are gonna try and say this isnt there fault, but why then didnt they say anything about it being bad???thanks for the replys thus far...
It very well may be the timing belt tensioner, but he's full of crap about the oil. You can check your oil with the motor running and it will show on the dipstick.
The timing belt and tensioner has to come out to change the crank and cam seals. Did you see any oil under the car in the under cover? Maybe they left out the crank seal or cam seal or messed it up. Even if the belt tensioner had the pin left in it and the belt skiped a few teeth or more there would still be oil in the engine.
I would be there asking questions and watching when it came apart.
Yes Sir!
Mitch Hansen
What I can't believe is that he would tell a customer some lame ass story about the oil pan. There is always, always oil in the pan when the engine is running.
I hope he is correct about the tensioner though Scott |
I think either way they should have seen it. If your motor turns out ot be blown up, then it's brobly their falt. Changing the seals requiers removal of the timing belt and tensioner, so if there was a problem with it they should have noticed and informed you. So if it ran out of oil because they didn't put it back in or because they screwed up a seal and it leaked out, or if it died because of a timing belt problem it's still there bad and they should fix it at there cost. Don't let them screw you over.
BTW. they will give a line about the insurence company not alowing costomers in the service bays. Unfortunatly for you it is true you shouldn't be in there.
true however,
Your experience may vary....
Mitch Hansen
