There is an SVX at a local junkyard. What should I grab?
It is a dark teal. I already snagged the front gray floor mats as they seemed in decent condition and offered those up for sale on the parts forum.
I also snagged the climate control unit (wood grain) and both key fobs. I grabbed both headlights as I may need those for my car. Same with the trunk struts and antenna The guy who junked it looked like he was trying to do the body work and gave up. He pulled a lot of parts off the car and they are just sitting in there. The rear light bar and both rear corners are in there and I can grab them. Same with the front corners. The air bag and ABS control units are still in there too. So is the speedometer cluster. I also left the rear floor mats as people don't seem to usually need those. The visors are gone. The engine is gone. Anything else I should pull?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-09-2019 at 04:08 PM. |
Re: There is an SVX at a local junkyard. What should I grab?
If you have room to store it the wind shield isn't available from Subaru any longer and the seal is also discontinued and might be salvageable if care is taken during the removal. The rear top strut mounts are also no longer available and are known to rust out. ? A/C condenser & evaporator ?, power window & lock controls are prone to failure.
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. Last edited by SVX_MY_BABY; 08-10-2019 at 01:35 PM. |
Any idea how long it's been in that yard?
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
What about the ABS and Air Bag controllers? Are they worth getting?
Condenser and evaporator were mutilated. Window master switch was also not in great condition. The only new thing I grabbed were the wiper arms. They seemed in better shape than mine.
Still wondering about the rear floor mats and the ABS and Air Bag controllers.
Thread Tools | |
Display Modes | |
