Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 02-20-2009, 04:19 PM
svxash's Avatar
svxash svxash is offline
ECU tune Transmission control unit?
Is anyone using this? If so what do you think and what other ECUtune products are you using it with?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 02-27-2009, 02:32 PM
Banned
Re: ECU tune Transmission control unit?
I have more questions to throw into the pile.
it looks like there are two options chipping or buying a whole new programed tcu, now is it the same thing if we install the chip our selves? Or is there a significant difference between the two?
Also is this set up for only the automatics? Is there a different set up for those of us who have swapped to the 5 or 6spd transmisions?
Old 02-28-2009, 02:31 PM
longassname's Avatar
Just some dude.
Significant Technical Input
It's only for autos. There is no difference between getting just the ROM and the complete TCU (assuming you don't botch the job of soldering your own tcu). I haven't added it to the website yet but I have also ported this over to the jdm tcu's at the requests of some Australians (they have to solder their own tcu's since I don't have them to socket).
Old 02-28-2009, 03:35 PM
oab_au oab_au is offline
The Australian car can not use the JDM or US TCUs. It uses a different speed sensor system.
One Arm Bloke.
Tell it like it is!
Old 02-28-2009, 03:37 PM
Just some dude.
My understanding was that the australian cars were jdm cars?
Old 02-28-2009, 03:44 PM
No we can't import JDM cars to here, as there was a model produced for this maket.
They import JDM to NZ.
One Arm Bloke.
Tell it like it is!
Old 02-28-2009, 03:47 PM
Just some dude.
ok so NZ cars are jdm and Australian cars are their own thing... don't they both use the same 3.7 vtd type trans? Do you know the tcu code/codes for the australian cars?
Old 02-28-2009, 03:56 PM
The cars produced for the Aust, New Zealand, and UK markets all use the same TCU, (as far as we know), all use the VTD with 3.7:1. All use the different speed sensor system, to the JDM that uses the same speed sensor system as the US model.
As for the Codes, you will have to ask the 'brains of the outfit', Phil.
One Arm Bloke.
Tell it like it is!
Old 02-28-2009, 03:59 PM
Just some dude.
Ok, thanks.
Old 02-28-2009, 04:03 PM
I have fitted out an Aust TCU with a 'Phil' modded ROM, to get switchable Power Mode, not installed yet, hope to get it in soon.
One Arm Bloke.
Tell it like it is!
Old 02-28-2009, 04:08 PM
Just some dude.
Great,
let me know if it doesn't work. I'll go ahead and port my maps over to the uk code now. With my maps you drive in normal mode drive and let the power mode be engaged by throttle application.
Old 02-28-2009, 04:16 PM
Just some dude.
I just looked at the uk maps and my us maps will port over to it without modifcation so I'll have it done tonight.
Old 02-28-2009, 04:18 PM
Great,
No that's not what we were after. Our TCU does not have the map that the US have to ground pin 4 to get switchable power mode. When we ground pin 4,we get Economy, Phil swapped the two maps, to achive Power mode.
The "power mode engaged by throttle application" is still active.
One Arm Bloke.
Tell it like it is!
Old 02-28-2009, 04:22 PM
Just some dude.
Your missunderstanding. I was just saying to let me know if the basecode from the UK doesn't match/work with the australian transmission.
With my maps there is no reason to modify the code to change the economy switch function into a power mode switch. With my maps you get better performance driving in normal mode and letting power mode be engaged by throttle application.
Old 03-01-2009, 08:34 PM
Banned
is there a way to still push my redlines with the 5 spd??? I still run the stock tcu with the 5 spd.
