Old 12-01-2008, 12:46 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
I think I broke my car.
Driving home on the freeway I dropped it into 4th to pass someone and think I pushed her too hard. After that pass it's been sputtering when I push the gas pedal, sometimes dying when moving slow. The CEL popped up but I haven't checked the code(s) yet, just wondering what I should be prepared for upon further inspection. It's a '92 with a 5 speed out of an 04 2.5rs, 107k on the clock.
Brian
Old 12-01-2008, 01:20 AM
kwren's Avatar
kwren kwren is offline
Re: I think I broke my car.
Sounds like you may have really broken it!
Keith
Old 12-01-2008, 07:40 AM
Wikedjuggalo's Avatar
Rebuilding
Idk but maybe be a simple MAF.
Old 12-01-2008, 08:03 AM
JaySVX's Avatar
JaySVX JaySVX is offline
MAF will do that. Also fuel pump, or clogged fuel filter. Maybe you sucked something into it that it didn't like.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 12-01-2008, 06:53 PM
Ricochet's Avatar
I brought some ham.
It was raining kinda hard when it happened but I didn't go through any big puddles. I'm going to check around this site to see how to get the code and go from there.
Brian
Old 12-01-2008, 07:07 PM
siceclipse's Avatar
siceclipse siceclipse is offline
spark plugs??
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 12-01-2008, 07:41 PM
Ricochet's Avatar
I brought some ham.
Pulled three codes. One for the EGR and both O2 sensors (32,34,37). The sensors are both less than a year old and I just had a new EGR solenoid installed. Sounds like the EGR took a crap, again....
Brian
Old 12-05-2008, 05:30 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Did you clear the codes out? Could be reading an old set of codes. I would have thought this is a MAF problem from what I read.
1995 Subaru Svx L / AWD
Old 12-05-2008, 09:31 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Sounds like the EGR may be stuck open. Was it OEM?? Since its newer you could clean it.... its not the worst thing to remove and reinstall on the SVX lol. Good luck !!!
Old 12-05-2008, 01:15 PM
Blenderhead Blenderhead is offline
The EGR is not supposed to be open under full accel. It is only supposed to be open at steady cruising. Having it open under accel would drastically reduce the power output of the engine.
It sounds to me like you have a misfire. The fact that it was raining at the time leads me to suspect a bad plug wire or something like that. If you have a misfire that the ECM hasn't picked up yet, it could throw O2 sensor codes and EGR codes. The O2 sensors will see the big gulp of air that the engine took and didn't fire, and think it is running very lean. The change on the vacuum reading in the intake when it misfires could be misinterpreted by the ECM as the EGR being open, since it calculates EGR flow based on manifold vacuum.
The first thing I would do to it is plugs and wires and see if that helps it at all.
Mike
MY TOYS
95 SVX
98 Lincoln MarkVIII LSC, 5-speed swap
91 Marcury Cougar, 393" stroker, completely insane!
89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt.
80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished.
Old 12-05-2008, 05:13 PM
michael's Avatar
michael michael is offline
What Potholes ???
Jumped timing belt?
Old 12-05-2008, 05:17 PM
longassname's Avatar
Just some dude.
Significant Technical Input
snorkel
xxxxxx
Old 12-06-2008, 01:28 PM
Ricochet's Avatar
I brought some ham.
I'm starting to think it goes even further past the plugs/wires to my alternator/battery. I found a hose half-connected to the egr so I clamped it back on. Might have been a symptom rather than the problem though, as it's still doing the same thing. When the car starts running rough, it'll die at a stop and I can't start it again unless I jump it.
So, I'm thinking the alternator isn't charging the battery, which doesn't give a spark, which causes that "gulp" of air across the egr/exhaust. Thoughts on that?
Brian
Old 12-06-2008, 02:14 PM
kwren's Avatar
This "can't start it again unless I jump it" is quite a clue.
A jump should do nothing for you that your electrical system in your car can't do for itself. Sounds like your voltage is not up to par if a jump works and your battery doesn't. Possibly the inadequate power could affect the idle but for sure it affects your cranking.
Translation... a jump works with the same voltage you are supposed to have in your battery, but your battery wont start it.
Keith
Old 12-06-2008, 02:18 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Yike !! Definitely check the alternator output first..... should be 14 volts or so while running (use a multimeter at the battery terminals). If its juicing the battery, suspect the battery is done. Ive seen plenty of new batteries with bad cells, so dont dismiss that as a possibility. If your alternator isnt putting out anything.... you read 12 volts or lower at the battery, you can hit the alternator with a solid metal object like a hammer... just give it a good ping.... and usually it will start charging again for a time, until you can get a new one. This trick worked for me for about 4 months on my toyota truck. You cant really diagnose your idle problem if your system isnt getting the right amount of current.
