Old 06-22-2004, 02:39 PM
tablu
Steering Problems
So the problem is not that the car doesn't steer...just that it leaks. I got underneath the car and saw that it is leaking from the rack and on to the exhaust=bad smell+ghetto fabulous smoke fumes from the wheel wells. Has anyone else had this problem? Is it really worth fixing (its a 92)? Anyone advise on what to do or where to get parts? Thanks
Scott
Old 06-22-2004, 05:47 PM
immortal_suby's Avatar
Thread Killah
Before you pull the rack I'd check the low pressure return hose - it can get brittle and crack letting the fluid seep out and then down onto the rack - making it look like the rack is leaking. It is a cheap and easy fix.
Locker Link
2015 BRZ Limited 6MT
Old 06-22-2004, 07:10 PM
It might help to clean the engine and then watch for the leak. Good luck.
Old 06-22-2004, 08:15 PM
tablu
Thanks for the input. I will check it out a little more.
Regards,
Scott
Old 06-22-2004, 09:16 PM
you might also try a search for the famous "o-ring" fix on the powersteering pump...its a quick fix and only cost a buck or two....which is substantially less then a rack...
Old 06-23-2004, 06:36 AM
dcarrb dcarrb is offline
If it's leaking onto the exhaust, you do need to get it fixed ASAP. A hot exhaust pipe can and will ignite ATF/PS fluid. Happened to me with another car.
dcb
Old 06-26-2004, 11:09 PM
tablu
My worries
I replaced the o-rings. It was leaking from them, one was broken and the other was close to breaking. However, the leak still continues. When I turn the wheel all the way to one side it leaks out of the right side boot. Is there an easy way to fix this or do I need a new rack? Maybe theres some magical mystery goo that you poor into the ps pump and it magically fixes all your problems...Its worth asking
Scott
Old 06-26-2004, 11:20 PM
tablu
How hard is it to change out the rack? I have a chilton guide which tells how to do it, sorta, the instructions are a little vague at points. Is it necessary to remove the left halfshaft to pull it out and how difficult is that? I have all the tools and can do the job, i would just like to know what I'd be getting myself into. Im sure there are some experts out there who can give me a few tips. Thanks
Scott
Old 06-27-2004, 06:52 AM
Thread Killah
I have not removed a rack, but if you need to take out the halfshaft to do it don't let that be a roadblock to you - they are pretty easy to take out.
Locker Link
