tire pressure front/rear
How important is it to have the rear tires @ 28lbs versus the fronts @ 32? I realize these may not be exact specs, but I'm really asking about the suggested differences between front and rear. Is it Ok to just have 'em all at 32?
Re: tire pressure front/rear
My Toyo's are all at 40 psi...seems fine...should I be worried
Jeez, Just follow what's on the doorjamb plaque unless you ride with a different section series, wheel diam. or want to autocross. Jump the pressures by a few pounds equally front and rear if you like. Remember these are "cold" pressures". Your skins will thank you. Balance is everything. B.
<<jiggle like jello>>
In other words...sidewall flex...lol |
As long as they're not showing any bad wear patterns just stay below the tire's recommended max inflation and above the door jamb recommendation. If they begin to show wear in the center, drop a few pounds, conversely add a few if wearing on both inside and outside edges.
I notice almost no wear in 3,000 miles. I love these tires. All season, cheap ($100/each) stick to the road like glue, matches stock size for the rim perfectly, have a 40,000 mile treadwear warranty, and don't hydroplane at 100 MPH in curves on a rainy day. No exageration, just plain stupidity. |
