Damn it, what did I do?
Was under the dashboard tonight changing the stock TCU with the ECUTune TCU. Got it changed out and bolted back in place, but now after reconnecting the battery the car won't start.
It will turn but not turn over and I hear a click from under the hood and also a clicking from under the dashboard even when the key isn't turning. There are a lot of wires in that area and not much room I hope I didn't mess something up. HELP!!!
Re: Damn it, what did I do?
Did you check the battery terminals to see if the are free from crud? Also I would double check any plug you see under there again just to be safe. You might have unpluged the ecu by accident.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Are you sure you plugged everything in right on the ECU? if you missed a plug your car wont start.
The terminals are clean and everything seems to be plugged in tight. The headlights light come on and the engine turns. When it turns, it dims the lights.
It's too dark and rainy to do more tonight, but tomorrow I will take out the ECU and the TCU. I need to check that the stage 1 chip is in the ECU tight. I have spares of both of those computers so I guess I can try replacing those. Sure hope I didn't break something.
battery is dead
in all seriousness.. try jumping it. I've had weirder things happen?
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
Yup. I'd try jumping it as well. May also want to give the starter motor a good tap to see if it's the starter (although unlikely).
I'll get back into tonight, I am thinking maybe the stage 1 chip came loose disabling the ecu. At least that is the 1st thing I am going to check.
