power mode on demand...maybe
I was thinking of making it so I can put the car into power mode via a switch. Yes, it is easy just to floor REALLY REALLY fast and get it into power mode. Then there are nights like last night, when you take off and the fool next to you wants to race and you cant get it there because you've already taken off and your foot is 1/2 way down.
Does anyone have any thoughts to this? I was thinking a simple pushbutton switch would deliver a pulse of whatever voltage the system wants into the line that turns on the powermode. Thus making it think i've stomped the gas FYI it was a buick centruy, from the late 80's, all ghetto pimped out. Not in powermode it kept up till it went into 2nd then I was about 1/2way past him when I had to slam on the breaks for a big truck |
Forced power mode
Yes it is possible to do that
you have to find the Tps - Throttle Position sensor. if i remember correctly. ( anybody jump in at anytime) in senses -5, +5 Volts to activate the power mode so if you just wire a switch in it should work. let me find the thread on power mode. |
just a thought
if you put a switch in to tell the tps +/- 5v won't the car think it is getting more air and add more fuel to compensate. then you would have to have your foot on the floor to get the throttle all the way open. doesn't the power mode only come on if the gas pedal is pressed fast from no throttle to full, if so you would have to release the gas press the button and stomp on the gas, still have a moment were the car is running rich. the better idea would be to run a switch directly to the computer or figure out if the power light completes the circuit and force the light itself to come on but I would not say to mess with other systems to trick it to come on like I said just a thought a long one |
Michael 1992 SVX Build 4/91 SOLD TO gsodonis 2002 Civic Si SOLD 2005 Lancer Evolution VIII TRADED 2008 STi |
My guess is the power light is only for show, that running voltage to it would not do a thing for the performance, so it's a matter of finding what switch is attached to the pedal. |
From what I've read, the power mode only changes the shift map to allow for near redline shifts.. Even if the power mode doesn't come on and you floor it, it's still going to take the car to near redline by itself.. Also, I believe the way the power mode works is the tps gets 5v, but when power mode is kicked in, the voltage drops to 0.. So you could basically wire in a switch, but wouldn't it be easier to wire in a switch for the dash light?
here's the link.. http://home.mgfairfax.rr.com/svx/faq/ "The 'throttle position sensor' or TPS is used by the ECU and TCU to read the throttle opening angle. The sensor reads from +5 volts closed to 0 volts at WOT. There is a direct connector between the ECU and TCU for the circuit. You could wire a switch into the line so you could switch the circuit off. As long as the circuit is off, the TCU will stay in power mode since the transmission will assume you instantaneously floored the accelerator (and are keeping it there)." |
Is this what it's come down to, racing pimps in a Buick Century? Things must be getting awfully boring in Michigan....
Beav |
power mode and other thoughts
Ok now my thought is not of HOW to do anything with this mod of wiring in a switch to have FULL time power mode. As I agree with Beav, I think it only changes the shift map for the transmission to hold a few seconds longer. To redline each shift.
However if you make the TCu think it's always at WOT.. Makes me wonder how Good your gas mileage will be? Of course I know few are thiking of gas mileage right now.. It seems some of the mysteries with the SVX is the ECU.. I"ve got a feeling there is a hidden something burried in the computers. THe other mystoryis, the trannies, and how to Keep them ALIVE. Beav is right if you just slam the gas, the trans will redline each shift anyhow. the power mode seems more like a cute light. Now if ya really wanted to havea trick, have it rigged that when the Green power light comes on FLames blow out the tail pipe... Of course with the plastic bumpers that might NOT be such a great Idea. midnight ramblings SVX1999 |
flames kick ass
Power Mode
Is it very bade for the tranny, if you do the full throttle too often?
mfg hrc
Ænima |
I don't believe there is much that can make our trannys go out any faster maybe just a louder thud.
I would worry more about burning up other systems , TPS, ECU, Catalytic converter and such. a switch to the TPS is diffintly not the way to go why not see about one of those powerchips out of australia, I believe that will remap you shift points |
Re: power mode and other thoughts
As for flames, that sounds sweet! Melt the saturn or kia behind me I dont know how well my bumper will hold up to that though...Here's something I saw last night at autozone while picking up a bulb... Got Rice? it's the 2nd one down, called the afterburner, or something like that. |
A few of our mor senior members may remember spark plugs in the tailpipes, powered by Model T coils. Pull the choke, hit the coils and voila!
Beav |
My buddy has a '49 ford flathead v8 sedan with the sparkplug/ flamethrower setup. At my bachelor party we torched off a 20 ft tall bonfire with it. There was alot of gas involved. I remember being too inebriated to be scared that the car would catch fire, Yes - it is all on video tape. I wish I could get the svx to do that. It must be fun at stoplights.
