Whts happening with my steering??
Hi,
Got a new problem. My steering is acting crazy now a days . Here is the exxact problem. The steering makes a lot of screeching noise when the car is started in the morning. At this time the steering is like a hell to turn (very tight) and when i try to turn it and make it loose or to get rid of noise, in this process of rotating whenever the steering becomes tight the steering, Battery, stop-lamp and ABS light up on the dashboard. After the car is heated up or after sometime of running the car, the noise dissappears and the steering wouldnt be tht much tight as it was at the time of cold start. But will show up sometimes when I try to trun the wheel full on either sides (completely right or left). Turning left is little tighter than turning right. The other symptom is, the steering is rotating freely (freely deosnt mean like a good steering, but comparitively free from idle) when i give some revs, but while idling it is acting tight. Using Valvoline-Synthetic p/s fluid. Any ideas/suggestions? Thinking of replacing the pump or rebuilding it with any necessary parts. thanks, -Pavan. |
Have you checked the fluid level?
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
the fluid is upto to the mark and I have replaced it last week with new fluid. thanks, -Pavan. |
Have you checked the drive belt condition/tension? A slipping belt will screech under load, as when you turn the wheel, and since the same belt drives the alternator, when it's slipping, the ALT isn't turning as fast as it should, causing the dash warning lights to illuminate.
If the belt's not worn or loose, the slippage could be caused by the idler pulley or PS pump is trying to seize. dcb |
Thanks -Pavan. |
Hope you don't have issues with your steering rack
"Using Valvoline-Synthetic p/s fluid"
Hate to tell you Pavan, but the Steering Box uses ATF, not p/s fluid. Check the How To section under Steering/Flushing etc. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
