NSK front wheel bearings packing grease?
I got the front bearing apart. I bought a bearing from NAPA, not Subaru. It is an NSK bearing. The grease in the bearing is clear/white. Is it packing grease or real grease?
Thanks, Stephen |
I know its a bit off topic, but I'm confused. Normally is the packing grease put on for storage? Do we have to soak it in alcohol or something to get it off and then repack with real bearing grease?
grease already in bearing.
That is exactly my question, Tim. Am I looking at packing grease, or real wheel bearing grease?
Getting the old bearing out of the hub was all my 12 ton press (and sledge hammer) could do. I'm not interested in a redeux. Right now, I'm going to repack the bearing with real grease without removing the existing grease with solvent. kind of a split the difference approach! *laughs* |
nsk are the o.e. bearings
repack them good and put them in
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
Re: NSK front wheel bearings packing grease?
Re: grease already in bearing.
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
