Please HELP!! does anyone know how to remove the Crankshaft Sprocket?
this Crankshaft Sprocket thing has to come off to replace the oil pump eral and o ring. It looks like it has 2 holes that bolt could be screwed into and that would push it off? If this is not the case, it ain't happening
I think you need to use a puller if its stuck on there.
thread those 2 holes with a metric 8x1.25 tap. The use a flat steering wheel puller to take it off.... DON'T pry it of from behind.... that will only bend the timing sprockets and break them
Tom |
good advice. ........and I have a main crank sprocket with busted off timing sensor teeth to prove it
Tom |
One question...
Is "up the duff" somehow related to a "plum duff"?
Oh, bugger all! Cheers! p.s Trevor: please read and comment as you feel appropriate on my post re: the two power steering systems & brakes
' 92 SVX @ 185K ' 91 420SEL @ 223K! ' 88 420SEL I. @ 178K (what a buy!) ' 87 F250 @ 180K ' 93 ZX-11D @ 29K ' 93 SC400 @ 93K 2001 Valkyrie Interstate @ 6.6K (Brynhild) Y2K NightHawk 250 @ 1,500 miles ' 88 420SEL II. @ 208K '85 F150 @ 135K |
The manual advises:-
Tap the two holes in the sprocket using a 8 mm, 1.25 mm pitch tap. Drill 10 mm holes on a 41 mm radius, in the plate on a puller. Fasten the plate to the sprocket using two M8 bolts. Use the puller centre bolt against the end of the crankshaft to remove the sprocket. On this basis a puller could be knocked up using a plate and a large nut and bolt.
Knocked Up???
Just another of those unexplainable differences in the supposed same language. Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Thanks everyone for your help!!! I really appreciate it! Take care everyone, Keith Last edited by ensteele; 07-07-2007 at 12:26 PM. |
Trevor?
