Old 04-09-2006, 11:59 AM
spinn360's Avatar
spinn360 spinn360 is offline
power mode still/again
So the car keeps going into power mode. Not just the power light coming on. but the actuall shift points changing to about 5 grand. I thought the tps was the culprit and it was replaced with a used one. took a while to set it as the butterfly valve wasnt closing all the way. ( I had to clean it ) Then got it set to .5v. Car ran good for about 1 week. then power mode started coming on. More frequently now. I am thinking it is the TCU. I paid for one, and its supposed to be on the way soon(I hope). the power mode came on yesterday when I was stopped at a stop light, at a freaking stop light! No gas applied, no change in throttle position!
I can turn it off when I am on the highway by turning the cruise control on, but when I do that, the tranny goes to 3rd gear even at 70 mph. When I am in town I can stop the power mode from coming on by pushing the manual button and shifting from 1st to 2nd gears manually. I am not sure but I thought I would post this to see if anyone else has had this prob. Or if anyone knows how to fix this. I am set at a very tight budget right now and I cant afford anything over 100 dollars so, I cant replace the TPS with a new one(besides the fact that I dont believe this would do anything). Someday maybe I will put the 5mt in but that will have to be further down the road. God I hate Automatics.
Please if anyone can help that would be great.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 04-09-2006, 02:56 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
I hope you get your problems sorted out. With all of the 5-speeds floating around, there have to be a lot cheap TCUs available.
With all of the SVXs out here in Oregon, I really wish we had a TomsSVX in the neighborhood!
Dan
Old 04-09-2006, 04:28 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Measure the voltage of the white wire at pin b8 of the TCU. This is the wire from the TPS to the TCU. With the throttle fully closed it should be 4.0 to 4.8 volts. At WOT, it should be somewhere between 0.7 and 1.7 volts. Go for a drive with the voltmeter connected and see what the voltage is when your spurious power mode occurs.
If power mode activates while the voltage is >1.7 volts then the TCU is at fault, otherwise the TCU is just doing what it is told.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-09-2006, 04:55 PM
oab_au oab_au is offline
Power Mode.
Could be the ATF temperature sensor in the trans, that is reading wrong. It will put it in Power Mode, to cool the ATF.
One Arm Bloke.
Tell it like it is!
Old 04-09-2006, 07:45 PM
Trevor's Avatar
Trevor Trevor is offline
Exactly which and what circutry will activate this feature, which I can not find refered to elsewhere. ?
Are you saying that this will raise the shift points at all degrees of throttle opening and will as a result, lower the transmission fluid temparature to a worthwhile degree ? If so, those with Power Mode switch could keep this mode in constant operation to advantage. It is strange that this idea has not been previously been brought up here.
Trevor.
Trevor, New Zealand.
Old 04-09-2006, 08:45 PM
SomethingElse's Avatar
word words wording
its probably some kinds of thermistor. resistance changes with tempreture..just like a coolant temp sensor. oh well no more automatic so i dont have to worry about it
Eric
Old 04-10-2006, 06:34 PM
My understanding was that the temp sensor was to serve 2 functions. Allowing the trans to stay out of 4th gear until the temo reached 50*F and then keepin the TC from locking until it reach 150*F(I think). Maybe this is what you were thinking? I have never heard of the temp sensor having anything to do with the power mode. Infact you can still engage power mode when it is freezing cold or fully warm.
Old 04-10-2006, 08:12 PM
word words wording
Fresh Fruit?
I dont have a garden path
Eric
Old 04-15-2006, 01:16 AM
Trevor's Avatar
Trevor ---- Are you saying that this will raise the shift points at all degrees of throttle opening and will as a result, lower the transmission fluid temparature to a worthwhile degree ? If so, those with Power Mode switch could keep this mode in constant operation to advantage. It is strange that this idea has not been previously been brought up here.
Harvey this is an interesting concept you have outlined and I had hoped for a reply to the above, as possible advantages of use to members are indicated.
I always drive in third within city limts in order to prevent the transmission from hunting up and down in and out of drive. Using power mode would move up the shift points, as I see it, only at full full throttle. But there should be no hunting betewen low and second. There is reason for further investigation, in order to possibly utilise this feature as a means of protecting the transmission against overheating. Circuitry must exist involving the ATF temperature sensor and it may be possible to incorporate some form of overide switch.
Others will be interested in this prospect and your reply will be appreciated, Trevor.
Old 04-15-2006, 01:55 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
When the power mode is on, the shift point will go higher. But it's not necessary when at full throttle, I could activate my power mode anytime as I wish, the way to do that is quickly put down some gas on the pedal no matter how much, as it's quick enough the power mode will be activated...
PS: I haven't done full throttle on my yellow one after the second swap...trying to take it easy first. (only 300miles driven) I tested it the other night...I only quickly moved down my throttle about 1/3, the power mode could raise my shift point at 5000rpm of the second gear.
Spinn360, as you said, your power mode will randomly activate. But could you activate your power mode when you want to?
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 04-15-2006, 03:49 AM
b3lha's Avatar
Phil & Belha
It has been brought up before. I remember this being discussed in the Euro forum some time ago, though I can't find the thread at present.
I keep the power switch on all the time except during motorway cruising. I've found that it does not seem to effect the overall fuel economy and I enjoy the more responsive feel. I also use position 3 a lot and hopefully these measures taken together will extend the life of the transmission.
There are so few of us with JDM cars that the idea is irrelevant to most people. I recently suggested that someone with a USDM SVX should try connecting a switch in the same way that the JDM one is connected and see if it works.
Does power mode definitely stop the TC from locking? As Earthworm said, that could be a downside due to the extra heat generated. I can never really tell whether mine is locked or not, but the SVX is always very responsive, power mode or not. When I press the pedal, the acceleration is *instant*. On all other automatics I've driven, (mostly Mercedes, but also Jaguar, Vauxhall, Peugeot and a few others), when I press the pedal, the rev counter climbs and then a few seconds pass before the car starts to accelerate.
Phil.
