ECU query
Hi All,
I have an New Zealand new 1995 SVX which is having ECU issues (OBD1); will JDM 1991 ECU work as a replacement? Or s there a firmware or wiring difference with different years? If firmware difference can they be updated? Cheers John |
Re: ECU query
John,
post some pictures of the part numbers from the unit...
Re: ECU query
Re: ECU query
I don't have the answer to your question, but here are some SVX ECU resources I've found useful in the past:
Overview: http://www.alcyone.org.uk/ssm/ecuinfo.html List of different ROM images: http://www.alcyone.org.uk/ssm/ecuroms.html How to modify the ECU image: http://www.alcyone.org.uk/ssm/ecumod.html Hope it's useful. Cheers, Ian. |
Re: ECU query
Many Thanks!
Re: ECU query
Hi All,
I received the following from Phil in the UK: "The different market ECUs are not 100% interchangable, the car will run but unless you are lucky, you will get error codes. If you need a replacement ECU then I would advise to try and get one from NZ, Australia, or the UK. Maybe Europe also, I'm not sure that all the European ones are the same though. The JDM cars have catalyst temperature sensors, a 180kmh speed limiter, and they don't have EGR control. The Euro/UK cars have EGR and I assume the Aussie/NZ ones are the same. The US cars have a different sort of EGR and an atmospheric pressure sensor. When I tried a UK ECU in my JDM car I got an error code because of no EGR system." Fingers crossed I am lucky! Has anyone installed any alternative ECUs? Cheers John |
