lol noob question (a/c)
maybe its broken but what is the air conditioning setting? i am gettin hot air, maybe my car is just hot from sittin in the sun but i dont leave anything on to see if cool air starts coming out because its too hot to drive :P
Re: lol noob question (a/c)
The lower you set the control temp, the colder the air will come out (assuming you have pushed the Auto button to turn it on in the first place. Econ will not let the A/C come one). If you set it to 65 and it's 30 out then the heat will come on. If you set it to 65 and it's 90 out then the A/C will come on.
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
last part isnt true. Whatever you set the temp to no matter what the temp is outside it will blow out at that temp. if you set it to 65 and shut it off it will blow cold air to you feet same with heat if you set it to say 85 and shut it off it blows hot air to you feet. Econ mode if i remember still runs the a/c but at a bare minimum hence Economy mode.
Econ mode doesn't run the compressor. Only Auto and defrost use the compressor.
Auto mode uses feedback from the ambient temperature in the car to change the air feed from hot to cold to make the in car temp match what you put the setting to. If you put it on 70 and it's 80 in the car it will blow cold air to get it down to 70 and then it will try to maintain that temp. If You put it on 70 and it's 60 in the car you will get heat to get it up to 70 and again try to maintain that temperature. Econ mode works similarly but you will not get AC compressor cooled air when trying to cool the temp down, only outside vented air. Once you turn it off though you are correct, if you left it blowing warm air when it was shut off, you'll get warm air. If you left it blowing cold air when shut off, you will get free air venting without heat.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 05-15-2012 at 07:27 PM. |
Econ= Economizer. If the outside air is below the set point, then it will use the outside air. If the temperature outside is above the setpoint, then it will switch to mechanical cooling (compressor). That is how economizers work on building A/C units. I think it would also apply to autos, if not, then what is the difference between the vent button and an econ button?
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
The "ECON" mode is the same as "AUTO" but the compressor stays off during all operation. |
Unfortunatly, Econ does not. If Econ does not reach your disired temperature, then you will need to switch to AUTO. Economizers usually do this for you automatically.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 05-17-2012 at 07:12 AM. |
I know this is old but I just hooked my ac up (idler pully was froze when I bought the car). So, if it is 64 outside the air will not come on? It is 64 here now and I am trying to see if it works but the compressor don't kick on. The front doesn't spin.
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS |
Does it have freon? Have you checked the 10 amp a/c fuse under the hood next to the fwd fuse slot?
